Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 58
Thread: Audio Artistry CBT36K kit
  1. #41
    agarwalro's Avatar
    agarwalro is offline Audioholic Samurai agarwalro should be listened to
    Join Date
    Jan 2005
    Location
    Central PA
    Posts
    2,711
    Thanks Given
    932
    Thanks Received
    613
    Default
    Quote Originally Posted by GranteedEV View Post
    hey man that sounds like a last name, would you prefer to be called by your first?
    They call me "Tater Salad" . Nah, I go by, 'Ro', short for Rohit. It is no biggy, Agar, Agarwal, Ro, Rohit, whatever. Thanks for the concern and a tip of my hat for great etiquette.
    This speaker is meant to be standing (or hanging) above (or below) the floor (or ceiling) in order to act as a line source. If you block off half the speaker's output with drywall, then you're effectively messing with the design.
    The CBT builds on the line source concept. It is half arc length of the semi-circular Legendre shaded array. It needs the floor bounce to compete the desired response.
    Home Office: Behringer 1030A, SVS PB-12 Ultra, measured. Comfy Room: PS3, Sennheiser RS120, Samsung UN46B8500. On the Go: Sansa Clip lost , Etymotic ER-6i commandeered by wife!
  2. #42
    GranteedEV's Avatar
    GranteedEV is offline Audioholic Ninja GranteedEV should be listened to
    Join Date
    Jul 2009
    Location
    Calgary, Canada
    Posts
    4,485
    Thanks Given
    1,967
    Thanks Received
    2,034
    Default
    Quote Originally Posted by agarwalro View Post
    I was close. I figured it was short for Rohan
    System: Marantz SR6003
    ---> Crown XLS 2000 ---> Philharmonic Model 2
    ---> Tapco Juice J2500 --> DIY Maelstrom X
    Victory goes... TO THOSE WITH COURAGE!!!
  3. #43
    Velcrofly is offline Audiophyte Velcrofly is a forum member in good standing
    Join Date
    Apr 2012
    Location
    Wichita Kansas
    Posts
    2
    Thanks Given
    0
    Thanks Received
    0
    Default Thanks for the thread
    Benbodtke,
    Thanks for starting this thread. I am an avid DIY'er. mainly 2ch tubes. vinyl. and a passion for all things audio. I'm looking for a new project and while researching vertical line arrays for my next design I found the CBT36. I am seriously concidering "pulling the trigger" on a pair. Like many others finding threads on the 36'es are far and few in between. paticularly anyone with an independent listening experiece. I am looking to experence a pair connecting them to a quad of home built KT-88 set mono block amps and an analoge active crossover. Again Im looking forward to following the thread.
  4. #44
    agarwalro's Avatar
    Join Date
    Jan 2005
    Location
    Central PA
    Posts
    2,711
    Thanks Given
    932
    Thanks Received
    613
    Default
    Hey that was a good guess. I'm assuming you have someone by that name in your circle .
  5. #45
    benbodtke is offline Junior Audioholic benbodtke is gaining some recognition
    Join Date
    Mar 2012
    Posts
    88
    Thanks Given
    12
    Thanks Received
    19
    Default
    BTW, Ben, I would try to avoid having any 90 degree corners if you do end up with a falsewall. Try to have large format 45 degree bevels where possible.
    Don't discount the possibility that maybe you don't even need a center. Perhaps stereo is perfect for your needs. Build the speakers first and then decide on the rest. I know I don't particularily care for center speakers, at least until I can do the whole AT screen thing myself.
    I dont plan on having any 90 degree corners, I will find the pic of the soundstage/falsewall that I am contemplating and post it here. I usually like center speakers but I need to hear these first to decide on whether I need one or not. Like you said, I may not need one.
    I am having a sample of that screen sent to me, should be here in a couple of days. Another DIY screen, I am going to be busy.
  6. #46
    Join Date
    Mar 2012
    Posts
    88
    Thanks Given
    12
    Thanks Received
    19
    Default
    Quote Originally Posted by Velcrofly View Post
    Benbodtke,
    I am just now getting the painting close to being done now. But I have been going through the manual and it doesnt seem to hard. I initially thought I would have to solder each tweeter to the driver, but they came attached already. That made it a ton easier.
    I am just using a couple of Crown amps, which I received today. Also going to set it up using the DCX2496, comes in tomorrow. I may change the stuff later on but for now I want to keep the cost down to please the wife.
    It has been a fun project so far, but its really just started. I will post some pics soon of the speakers, they are not the greatest, and if I am not satisfied with them when I am done, straight to the automotive shop for painting.
  7. #47
    agarwalro's Avatar
    Join Date
    Jan 2005
    Location
    Central PA
    Posts
    2,711
    Thanks Given
    932
    Thanks Received
    613
    Default
    Hi Velcrofly, welcome to the forum.
    You will need a DSP processor (like the DCX2496, DEQX or mini DSP) in which to implement the 16 filters per channel. Combined they constitute the crossover, constant directivity shelf and response eq, all the while keeping phase fairly constant across the board. Most likely, the analog crossover by itself will not work for the CBT 36.
  8. #48
    GO-NAD!'s Avatar
    GO-NAD! is offline Audioholic Ninja GO-NAD! should be listened to
    Join Date
    Apr 2009
    Location
    Nova Scotia, Canada
    Posts
    3,067
    Thanks Given
    3,699
    Thanks Received
    1,428
    Default
    As has been mentioned by agarwalro (hey man that sounds like a last name, would you prefer to be called by your first? ) you'd be blocking off half the speaker. This speaker is meant to be standing (or hanging) above (or below) the floor (or ceiling) in order to act as a line source. If you block off half the speaker's output with drywall, then you're effectively messing with the design.
    Line sources are best when vertical, as they minimize offensive vertical reflections while maximizing desirable horizontal reflections. That is why we want it be behind an AT screen, as flipping it on its side would probably have ill effects on the perceived multichannel soundstage (though probably not the timbre, luckily).
    Whoa, hold on!
    We appear to be talking about two different things. Perhaps I should've been more clear about what I consider to be a false wall for an AT screen. I consider - by default - that a false wall for an AT screen to be acoustically transparent as well. Just framework covered by speaker grill cloth. I certainly wouldn't use drywall!
    I thought that was a given, but I guess I shouldn't assume that everyone is on the same page as me. My apologies.
  9. The Following 2 Users Say Thank You to GO-NAD! For This Useful Post:
    agarwalro (04-14-2012),GranteedEV (04-13-2012)
  10. #49
    Join Date
    Apr 2012
    Location
    Wichita Kansas
    Posts
    2
    Thanks Given
    0
    Thanks Received
    0
    Default Center Channel and Surround Alternatives
    Okay I'm just spit balling here and a 2ch guy so don't beat me up to bad but, I had a moment.
    What if rather than using 1 whole speaker for the center channel cut it into 3 equal segments. Each having 6 speakers and 18 tweeters. The center channel would have no power tapering because if mounted horizontally you want off axis symmetry and the rear or surrounds in a 5.1 system could be hung from the ceiling. The smaller segmented speakers would still maintain the same arc and use the ceiling rather than the floor for the reflective properties. This in someway resembles a free standing vertical line array much like you see at a concert. I know you can't buy just one speaker so if you had a 2nd pair some subset of the 2 could complete a 7.1 system.
    Again just a thought.
    As far as painting I did send a project to the body shop once. A pair of Lynn Olsen Aerial Mk VI's I built myself in 2003 are now in Cadillac Escalade White Diamond. They really look nice however the horizontal imaging narrowed. The sweet spot became about 24"X24" in an equilateral triangle from the speakers. Each speaker is aprox 135lbs so I don't think the natural freq changed. Probably a standing wave issue with the glossy paint. Not saying this will happen to you. Just my experience and excited to hear about the sound check.
  11. #50
    Solid-State is offline Banned Solid-State is off the scale
    Join Date
    Mar 2005
    Posts
    191
    Thanks Given
    10
    Thanks Received
    6
    Default
    Quote Originally Posted by benbodtke View Post
    The first coat of primer just went on the first tower. I hope I get this right. I am going to Hedahls tomorrow to have them shoot my sub for color. Then get them to make the automative paint for that color. A little more expensive but its worth it. I was thinking the sub color which is rosenut for the sides and back, and a high gloss black for the faceplate. Well those are my thoughts, any other suggestions...
    you really need to seal MDF!
    uhh... one sec I have a post on another thread regarding this stuff.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
