Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 58
Thread: Audio Artistry CBT36K kit
  1. #11
    benbodtke is offline Junior Audioholic benbodtke is gaining some recognition
    Join Date
    Mar 2012
    Posts
    88
    Thanks Given
    12
    Thanks Received
    19
    Default
    The black is on and the faceplate will be painted tomorrow. A little quicker than I anticiapated but coming along nicely. Should start wiring next week. I have pics but dont think anyone is too much interested in paint.
  2. #12
    agarwalro's Avatar
    agarwalro is offline Audioholic Samurai agarwalro should be listened to
    Join Date
    Jan 2005
    Location
    Central PA
    Posts
    2,711
    Thanks Given
    932
    Thanks Received
    613
    Default
    Home Office: Behringer 1030A, SVS PB-12 Ultra, measured. Comfy Room: PS3, Sennheiser RS120, Samsung UN46B8500. On the Go: Sansa Clip lost , Etymotic ER-6i commandeered by wife!
  3. The Following User Says Thank You to agarwalro For This Useful Post:
    STRONGBADF1 (04-08-2012)
  4. #13
    Join Date
    Mar 2012
    Posts
    88
    Thanks Given
    12
    Thanks Received
    19
    Default
    I will upload some more pics soon. I want to get further along first, I have been working alot so it has slowed my progress. I have however been ordering goodies. Got the receiver in today, and got the amps on order. Will order the crossover tonight too probably. Still need to order a screen for the projector as well. So will have to do some research on that too.
  5. #14
    smprather is offline Audiophyte smprather is a forum member in good standing
    Join Date
    Apr 2012
    Posts
    2
    Thanks Given
    0
    Thanks Received
    0
    Default
    I'm mildly obsessed with these speakers. I'm dying to hear how they sound, 2cd hand at least. I so wish I could do an A/B with my Sonus Fabers.
    What signal processor are you using? Have you looked at the MiniDSP? I have one to massage my dual-LLT's with. What does Audio Artistry recommend?
    Thanks for taking the dive Ben. 3rd party reviews of this kit are woefully missing on the web. I wonder why the "pro" reviewers hardly ever lower themselves to review kits.
  6. #15
    Join Date
    Mar 2012
    Posts
    88
    Thanks Given
    12
    Thanks Received
    19
    Default
    Well I talked with Don and he said to use the dcx2496 for a crossover. I just grabbed a couple of crown amps to power them. I will be ready to put them together next weekend. I cant wait to hear them either but really won't get to test them till Sep/Oct fully
  7. #16
    agarwalro's Avatar
    Join Date
    Jan 2005
    Location
    Central PA
    Posts
    2,711
    Thanks Given
    932
    Thanks Received
    613
    Default
    MiniDSP makes a good alternative to the DCX. You trade some flexibility and gain ease of use. The miniDSP is cheaper too.
  8. #17
    GranteedEV's Avatar
    GranteedEV is offline Audioholic Ninja GranteedEV should be listened to
    Join Date
    Jul 2009
    Location
    Calgary, Canada
    Posts
    4,484
    Thanks Given
    1,967
    Thanks Received
    2,034
    Default
    Quote Originally Posted by agarwalro View Post
    While I'm sure someone with understanding, CAD, and skill could get the same response out of a miniDSP that Don got out of the DCX, I would not currently lead OP in that direction. John Krevosky worked with the miniDSP for the Nao Note and found it's not as simple as just plugging in the same numbers into the software, even if the final results are not dissimilar from analog or other DSP options. There are conversions involved and verication is important.
    I would stick wiuth something already in place (which seems to be DEQX and DCX2496, and apparently DBX Driverack), though it would be nice if Audio Artistry could add miniDSP to that list. The only way to do it correctly would be to send a miniDSP to Don Keele and have him learn and work with the product.
    System: Marantz SR6003
    ---> Crown XLS 2000 ---> Philharmonic Model 2
    ---> Tapco Juice J2500 --> DIY Maelstrom X
    Victory goes... TO THOSE WITH COURAGE!!!
  9. The Following User Says Thank You to GranteedEV For This Useful Post:
    agarwalro (04-08-2012)
  10. #18
    agarwalro's Avatar
    Join Date
    Jan 2005
    Location
    Central PA
    Posts
    2,711
    Thanks Given
    932
    Thanks Received
    613
    Default
    Quote Originally Posted by GranteedEV View Post
    +1 for tried and tested.
    The CBT36 assembly manual gives a step by step for setting up the DCX2496. That alone may justify the extra price for some.
    Page 81 of the manual gives a tabulated list of filters applied. It should be fairly straightforward to recreate the overall crossover and eq. Operative being, should. No comment on whether it will sound same or not.
  11. #19
    Join Date
    Mar 2012
    Posts
    88
    Thanks Given
    12
    Thanks Received
    19
    Default
    Well there wasnt too much extra cost, I put in an offer at UniqueSquared and they accepted it at $220 I believe. It might have been $225, cant remember. But I did order it last night.
    So I have everything I need for the speakers now, and the only thing I have left to order for the HT is the screen and seating. I am meeting with the builder tomorrow to discuss structural changes and will discuss wiring as well in the room.
    I believe they are breaking ground in a couple of weeks, getting close.
  12. #20
    GranteedEV's Avatar
    Join Date
    Jul 2009
    Location
    Calgary, Canada
    Posts
    4,484
    Thanks Given
    1,967
    Thanks Received
    2,034
    Default
    Quote Originally Posted by benbodtke View Post
    False Wall / Acoustically Transparent screen!!! That way you can do a vertical CBT as a center!!
    Also, apparently these guys http://www.rtheaters.com are blowing out their berkline seating on clearance.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
