Results 1 to 10 of 10
Thread: Help me build my second sub
  1. #1
    E-A-G-L-E-S is offline Full Audioholic E-A-G-L-E-S has a small fan club
    Join Date
    Aug 2007
    Posts
    456
    Thanks Given
    89
    Thanks Received
    17
    Default Help me build my second sub
    I bought a SVS PB12-NSD a couple weeks ago. I love it, always clean and fairly visceral.
    I want a second sub to fill in the weak spots in my listening area and have decided to give myself a project.
    To start, what materials/tools/attachments will I need besides this list:
    -1" mdf
    -500w plate amp(oaudio or PA 500w bash) -- or -- Behringer ep2500
    -no show wood screws
    -titebond or gorilla wood glue
    -driver of choice
    -router
    -jigsaw
    I do not have a size limitation per se, but would love to stay as small as the perfromance I'm looking for will allow.
    As far as desired performance I want to "at least" match the SVS's FR sweep, if not best it at least above 25Hz.
    So anywhere from 2.5 cu ft to 6 cu ft lets say as that is pretty large and my pb12 is ~3.8 cu ft.
  2. #2
    jinjuku's Avatar
    jinjuku is online now Moderator jinjuku should be listened to
    Join Date
    Apr 2007
    Location
    Louisville, KY
    Posts
    4,173
    Thanks Given
    612
    Thanks Received
    1,408
    Default
    The Infinity Reference 1262w in a 1.2 cubic foot sealed enclosure and Behringer iNuke 3000DSP and have a channel in reserve for a 3rd sub later one.
    Let the SVS handle 40 and down.
    HT: L-C-R Zaph ZDT3.5's | AVR: Denon 4308Ci | Source: HTPC (Radeon 5k series - AMD Sempron 140 - 4TB server) | Sub:Infinity Reference Dual Opposed | Behringer iNuke 3K-DSP
    2.0: Mission Statements | Amp: Crown XLS402D | Source: AMD Brazos CPU | 96GB SSD | 4GB | Win7 x64 | E-Mu 1212m PCIe | Tripplite PR-10 DC Power Supply | Mini-box DC to DC ATX
  3. #3
    Join Date
    Aug 2007
    Posts
    456
    Thanks Given
    89
    Thanks Received
    17
    Default
    Quote Originally Posted by jinjuku View Post
    Without an EQ:
    1. How would I have seperate x-overs from AVR out? My Denon 1910 has just one sub out, so when I had my dual 8's I ran a splitter, but had just one x-over point.
    TIA!
  4. #4
    jinjuku's Avatar
    Join Date
    Apr 2007
    Location
    Louisville, KY
    Posts
    4,173
    Thanks Given
    612
    Thanks Received
    1,408
    Default
    Quote Originally Posted by E-A-G-L-E-S View Post
    Without an EQ:
    TIA!
    You have to provide management for each channel. So you will defeat the x-over on the receiver (if optional) and use the X-over on the SVS and the X-over on the iNuke 3000DSP (along with EQ function if needed).
    You will still run the splitter still and just use each amps X-Over and EQ function.
  5. #5
    miniSQ is offline Junior Audioholic miniSQ is a forum member in good standing
    Join Date
    Aug 2010
    Posts
    59
    Thanks Given
    0
    Thanks Received
    3
    Default
    The sub you have is a 12" powered sub valued at around $500. The only sensible thing to do here is buy another matching sub.
    Mixing and matching is not going to improve anything....and in fact will much more likely make it worse.
    Also its unlikely that you will save any money here over going with a second SVS.
  6. #6
    Join Date
    Aug 2007
    Posts
    456
    Thanks Given
    89
    Thanks Received
    17
    Default
    These new SVS amps are apparently awful to use, incorporating a 10db something or other?
  7. #7
    Join Date
    Aug 2007
    Posts
    456
    Thanks Given
    89
    Thanks Received
    17
    Default
    Quote Originally Posted by miniSQ View Post
    $769 shipped. I built a Tempest-X/Behringer EP2500 a few years ago for $700.
  8. #8
    jinjuku's Avatar
    Join Date
    Apr 2007
    Location
    Louisville, KY
    Posts
    4,173
    Thanks Given
    612
    Thanks Received
    1,408
    Default
    As long as the drivers have roughly the same sensitivity integration with a flexible x-over isn't going to be an issue.
    I don't know if I would personally go down this route vs just picking up another of same like sub but it is doable.
  9. #9
    Join Date
    Aug 2007
    Posts
    456
    Thanks Given
    89
    Thanks Received
    17
    Default
    The reason I don't want to go that route is two fold:
    1. If I was going to buy ID again, I might as well sell my single PB12 and buy an HSU VTF-15H....as one 15H gives 5-8db more from 30-80hz.(which is essentially equal to two PB12's.
    2. I wanted to build a sub
    I suppose I could sell the PB12 and try buidling a very high power single sub.
  10. #10
    jinjuku's Avatar
    Join Date
    Apr 2007
    Location
    Louisville, KY
    Posts
    4,173
    Thanks Given
    612
    Thanks Received
    1,408
    Default
    Didn't you just purchase that SVS? The Infinity Reference is a high value proposition. From everything that I have read it is a true sleeper. No one has complained about the SQ. Just lauded it.
    That with the iNuke 3000DSP and you have a potent combination. Can you put the amp somewhere so the noise isn't an issue?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
