Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: THTLPX2 Build Thread
  1. #11
    Nestor is offline Full Audioholic Nestor should be listened to
    Join Date
    Dec 2006
    Location
    Small Town Ontario, Canada
    Posts
    316
    Thanks Given
    32
    Thanks Received
    58
    Default
    Progress slowed yesterday, so I combined the last two days into this post.
    So yesterday, I began measuring out the braces for the baffle, when I realized I didn't have a safe way to cut such small pieces. The Festool saw would be safer, but difficult with such small pieces, and jigsaw would be messy. The best option would be the table saw, but I needed a jig if I wanted to increase my chances of keeping all of my fingers. A "sled" was in order...
    You can find different versions in google. This one is basically the design from Bill Fitzmaurice's site, where the THT plans are. I used hardwood (oak) for the back, and "Miter-slider" tracks from Lee-Valley. Worth the time and effort to build and make as straight and true as possible.
    After building the sled, I had enough time to cut and install the first set of braces...
    Number of braces varies with box width. Mine needs three, with the one in front of the speaker modified to ensure clearance from the speaker cone.
    Things went much quicker today. Sequence was fairly repetitive. Cut and install panel; cut and install braces; repeat.
    Continued on next post...
    Yamaha: RX-A3000, CDR-D651 CD Recorder, 2 X THTLP (36");Bash300S; Klipsch: R-F83, RC-64 Ctr, RS-62, RB62, RB42; Sony: BDP-S350 Blu-Ray; Samsung PN63C8000 63"; Squeezebox and Controller; Interconnects-Many
    Relegated-to-secondary system: RX-V2700, Klipsch RB25, Paradigm PW-2200 sub;
    No trees were killed in the sending of this message; however, a large number of electrons were terribly inconvenienced.
    My THTLP Build Thread
  2. #12
    Join Date
    Dec 2006
    Location
    Posts
    316
    Thanks Given
    32
    Thanks Received
    58
    Default
    ...continued from last post...
    One thing the instructions doesn't mention is being careful not to push the braces too far in, as it could create a bulge. For the last set in the previous picture, I set a guide on top of the cabinet and shoved in the brace just until it started to lift, then pulled it back until the guide settled flat. Also, though the brace will be tight when dry fitting, it can slide in A LOT farther when greased up with PL.
    Home-stretch (I think) tomorrow...
  3. #13
    Join Date
    Dec 2006
    Location
    Posts
    316
    Thanks Given
    32
    Thanks Received
    58
    Default
    Last main panels in place...
    Still some fiddly bits to cut for bracing in the driver chamber, install driver and wiring post, button up and test.
  4. #14
    Join Date
    Dec 2006
    Location
    Posts
    316
    Thanks Given
    32
    Thanks Received
    58
    Default It lives!
    After burning up the day in the city to exchange the bad piece of plywood, I finally got back to it...
    Braces and rim installed...
    Bottom access cover cut, braced and weather-stripped...
    Overhang trimmed...
    I decided to bring the speaker into the family room to install the driver and leak check. Speaker was heavy enough!
    This beast dwarfs my 63"!
    I had an extra 100W amp handy so I set it up with that for now. It'll take some more playing around, but I'm very happy with it. The heart beat in Dark Side of the Moon revealed some loose parts in my fireplace. "Busy Child" by Crystal Method was startling. I can tell the THT is reaching depths I had only heard/felt in my car stereo. I can only imagine what this will be like with the Bash 300W's.
    And yes, I've already begun the second THT LP.
  5. #15
    Join Date
    Dec 2006
    Location
    Posts
    316
    Thanks Given
    32
    Thanks Received
    58
    Default
    Hopefully I've provided enough meaningful info in this thread.
    With the second sub underway, I expect this build to go much quicker.
  6. The Following User Says Thank You to Nestor For This Useful Post:
    darien87 (03-18-2012)
  7. #16
    darien87's Avatar
    darien87 is online now Audioholic Ninja darien87 should be listened to
    Join Date
    Nov 2005
    Location
    Bay Area Cali, but San Diego is home
    Posts
    4,495
    Thanks Given
    740
    Thanks Received
    772
    Default
    Holy crap that things huge! I'm gonna go out on a limb and assume you're single.
    Samsung 64" 3D Plasma
    Emotiva UMC-1
    Emotiva XPA-5
    Onkyo M-501
    Playstation 3
    Samsung BD-P1600 BD player
    Boston VR2 fronts
    Boston VR12 center
    Boston VRX side surrounds
    Boston CR9 rear surrounds
    Rythmik Servo-12" Sealed, built by Guy Audio, Me
    DIY sub with 15" CSS sub and dual 18" PR's
    Behringer EP4000
    Elemental Designs eQ2
    Belkin PF31
  8. #17
    Join Date
    Dec 2006
    Location
    Posts
    316
    Thanks Given
    32
    Thanks Received
    58
    Default
    Quote Originally Posted by darien87 View Post
    Why yes, what made you think that?
  9. #18
    darien87's Avatar
    Join Date
    Nov 2005
    Location
    Posts
    4,495
    Thanks Given
    740
    Thanks Received
    772
    Default
    Quote Originally Posted by Nestor View Post
    Because that gigantic-*** box against the wall has ZERO WAF.
    Emotiva UMC-1
    Emotiva XPA-5
    Onkyo M-501
    Playstation 3
    Boston VR2 fronts
    Boston VR12 center
    Behringer EP4000
    Belkin PF31
  10. #19
    Join Date
    Dec 2006
    Location
    Posts
    316
    Thanks Given
    32
    Thanks Received
    58
    Default
    Assembled, but unfinished, I completely agree.
    Veneering and trimming to follow after completion of the second THTLP.
  11. #20
    TheWarrior is offline Audioholic TheWarrior has a small fan club
    Join Date
    Sep 2011
    Location
    GA
    Posts
    202
    Thanks Given
    140
    Thanks Received
    46
    Default
    If I've learned nothing else from this forum, its that there are some cool Canadians hanging around here...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
