Page 7 of 7 FirstFirst ... 567
Results 61 to 68 of 68
Thread: My Statements Build
  1. #61
    jinjuku's Avatar
    jinjuku is offline Moderator jinjuku should be listened to
    Join Date
    Apr 2007
    Location
    Louisville, KY
    Posts
    4,174
    Thanks Given
    613
    Thanks Received
    1,408
    Default
    Quote Originally Posted by JimAckley View Post
    I'm pretty amazed at how much they don't cost, per se. I think I'm going to try to offload my LSi25s and give these a shot.
    Edit: I do, however, think I'm going to go for higher end crossover components than what they used.
    While the designers don't think it will do you much good, in the overall scheme of things it's not a large chunk of change given the return you get on the speakers overall.
    I justified a $500 router and table building the Statements
    HT: L-C-R Zaph ZDT3.5's | AVR: Denon 4308Ci | Source: HTPC (Radeon 5k series - AMD Sempron 140 - 4TB server) | Sub:Infinity Reference Dual Opposed | Behringer iNuke 3K-DSP
    2.0: Mission Statements | Amp: Crown XLS402D | Source: AMD Brazos CPU | 96GB SSD | 4GB | Win7 x64 | E-Mu 1212m PCIe | Tripplite PR-10 DC Power Supply | Mini-box DC to DC ATX
  2. #62
    Swerd's Avatar
    Swerd is offline Audioholic Samurai Swerd should be listened to
    Join Date
    Sep 2004
    Location
    Gaithersburg, MD
    Posts
    2,274
    Thanks Given
    449
    Thanks Received
    1,529
    Default
    If you do, be sure to get the exact size and gauge inductor coils that are specified in Jim Holtz's design. It may be tempting to get fatter wires, but their lower DC resistance will change the overall circuit impedance of the crossover, and change its behavior.
    I'm not going to debate the merits of more expensive capacitors or resistors with you. Feel free to spend what you like. It's your project. But be aware that many DIY builders have made serious efforts to determine if "high end" capacitors or resistors make an audible difference. They clearly showed that no one could tell the difference between inexpensive or high end caps and resistors as long as their electronic values were the correct ones.
    Good luck with your build. The cabinet may be complex, but according to jinjuku, it's worth it.
    HT System
    Rcvr
    B&K AVR 507 Amp B&K EX4420 (main speakers) Main speakers Salk SongTower QWT Center Salk SongCenter Surrounds NHT SuperZero Subwoofer DIY PE RS 12" HF 2 ft³ cabinet with HPSA 500 amp BR player Panasonic DMP-BDT500 TV Panasonic TC-L37G1 Phonograph ARxa, Sumiko Oyster cartridge & Audio Technica PEQ3 preamp
    SongTower Listening Impressions - Photos
    2-channel system
    CD Player
    Sony CDP-591 Pre-amp Marantz 2230 stereo receiver Amplifier B&K ST-140 Speakers DIY 2-way CAOW1
  3. #63
    jamie2112's Avatar
    jamie2112 is offline Audioholic Warlord jamie2112 should be listened to
    Join Date
    Oct 2007
    Location
    in a bong
    Posts
    7,869
    Thanks Given
    3,099
    Thanks Received
    2,557
    Default
    Damn son,I have been missing all the action being on tour......oh well you did a hell of a job with those bro............
  4. #64
    JimAckley is offline Enthusiast JimAckley is gaining some recognition
    Join Date
    Jun 2011
    Location
    Dallas, TX
    Posts
    23
    Thanks Given
    0
    Thanks Received
    5
    Default
    Quote Originally Posted by Swerd View Post
    I'm not going to get too crazy with the caps/resistors, and have modded enough to know better than to mess with inductors. I'm not talking about going with ClarityCap MR 600v caps or something insane like that. I plan on sprucing up the HF and MF with some slightly nicer parts, e.g. ClarityCap ESA 250v Duelund, etc., but I'll most likely keep the LF circuit the same.
    Also, while I'm here I've been meaning to ask: IIRC, the internal volume needs to decrease 20% and the port needs to be tuned 3Hz higher, due to the new non-shielded woofers, correct?
    Quote Originally Posted by avnetguy View Post
    I have found that receivers, speakers and even cables for that matter have a "burn in" period which they appear to sound amazing for approximately 18-26 days or so.
    Coincidentally or not, this coincides with the "grace period" on my Visa card.
    Steve
  5. #65
    jinjuku's Avatar
    Join Date
    Apr 2007
    Location
    Louisville, KY
    Posts
    4,174
    Thanks Given
    613
    Thanks Received
    1,408
    Default
    Correct. According to Curts web site the Sd on the unshielded drivers is a little lower.
    Just take it from the height.
  6. #66
    Join Date
    Jun 2011
    Location
    Dallas, TX
    Posts
    23
    Thanks Given
    0
    Thanks Received
    5
    Default
    Just pulled the trigger on four RS225-8 woofers since they were on special, and grabbed the Dayton WT3 tester + precision scale combo since the scale was "free". I'm not sure if I really need it, but figured it would be fun to at least try out. Worst case, I decide it's useless and send it back, but I'm sure that as I get more and more into the DIY thing, it'll become more useful. (this is where one of you gurus tells me if I'm onto something, or if I'm a moron )
    Do you guys think the silver-faced NeoCd3.0 would look good next to the W4s, or should I stay with the black?
    Jin, I swear I'll stop highjacking your thread soon I just figured this would be a good place to start with my questions since you've already gone through this whole project.
    Steve
  7. #67
    jinjuku's Avatar
    Join Date
    Apr 2007
    Location
    Louisville, KY
    Posts
    4,174
    Thanks Given
    613
    Thanks Received
    1,408
    Default
    I think the silver faced tweets would look nice with the mid's. The woofer tester is nice in instances where you don't know the T/S params of a speaker for sure.
  8. #68
    GranteedEV's Avatar
    GranteedEV is offline Audioholic Ninja GranteedEV should be listened to
    Join Date
    Jul 2009
    Location
    Calgary, Canada
    Posts
    4,485
    Thanks Given
    1,967
    Thanks Received
    2,034
    Default
    Yes, however it's possible the 12 or 10awg equivalent air core has the same dc resistance.
    System: Marantz SR6003
    ---> Crown XLS 2000 ---> Philharmonic Model 2
    ---> Tapco Juice J2500 --> DIY Maelstrom X
    Victory goes... TO THOSE WITH COURAGE!!!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
