Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: JBL Vintage Speaker Restoration Done Right by Simply Speakers
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow JBL Vintage Speaker Restoration Done Right by Simply Speakers
    There is an old axiom I love to live by, “if it ain’t broke, don’t fix it”. Just because your speakers are old, doesn’t mean they can’t still perform as good and sometimes better than the models that replace them from the very same company. When I noticed my JBL Pro III speakers weren’t sounded as good as I remembered, I realized it was time to take some action. My beloved little speakers fell victim of aging so I elected the services of a company called Simply Speakers to restore them to their original working condition. Not only did they oblige, but they took it to the next level by doing a first rate job while also offering a modification to improve their performance. They proved to me that it’s hip to be vintage. If you’ve got some old speakers lying around that you’re fond of in need of a little TLC, I highly recommend Simply Speakers as your #1 choice for the task.
    Discuss " JBL Vintage Speaker Restoration Done Right by Simply Speakers" here. Read the article.
  2. #2
    aarond is offline Full Audioholic aarond has very reliable input
    Join Date
    Sep 2003
    Location
    CA
    Posts
    357
    Thanks Given
    33
    Thanks Received
    17
    Default
    $15.00! Is that the good buddy x employ discount! I don't know of anyone in the Los Angeles area that will even look at a loudspeaker for $15.00. I have a pair of jbl L65's and a pair of L110's. I think that the least amout I ever paid was $75.00 per speaker for refoam and that was 7 years ago.
    denon avr 3802
    lg bd650 bluray
    denon dvd2900
    sangean hdt-1 hdradio tuner
    lg 50pk950 50" plasma
    jbl s312II
    jbl scenterII
    jbl s36II
    jbl s36II
    2 x rocket ulw-10
    music room
    marantz 2230 receiver
    marantz 6300 turntable
    jbl l65 jubal loudspeakers
  3. #3
    ned
    ned is offline Full Audioholic ned is gaining some recognition
    Join Date
    Jul 2004
    Posts
    352
    Thanks Given
    33
    Thanks Received
    8
    Default
    Emailed them for inquiries but got no response.
    Front: NOW RBH 1266 SER, 661 LSE modified, 61 LSE, 441 se, 641 se
    Rears: RBH 66se, 41se
    SUB: SVS, Emo
  4. #4
    gene's Avatar
    gene is online now Supreme Audioholics Overlord gene should be listened to
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,818
    Thanks Given
    819
    Thanks Received
    2,401
    Default
    Where did you come up with $15? The service they did on my speakers was slightly under $90 for everything.
    L65s are a classic. I haven't seen those in quite some time. I bet they are quite good performers.
    Try emailing Sean the owner at: info@simplyspeakers.com
    He is usually very responsive from my experience.
    Gene DellaSala
    President, Audioholics
    Pursuing the truth in audio & video...
  5. #5
    Join Date
    Sep 2003
    Location
    CA
    Posts
    357
    Thanks Given
    33
    Thanks Received
    17
    Default
    Quote Originally Posted by gene View Post
    from the invoice $15.00 labor per speaker
    denon avr 3802
    lg bd650 bluray
    denon dvd2900
    jbl s312II
    jbl scenterII
    jbl s36II
    jbl s36II
    2 x rocket ulw-10
    music room
  6. The Following User Says Thank You to aarond For This Useful Post:
    gene (08-04-2009)
  7. #6
    Join Date
    Sep 2003
    Location
    CA
    Posts
    357
    Thanks Given
    33
    Thanks Received
    17
    Default
    these are part of my vinyl listening system along with a Technics SL-1200MK2 and a Kenwood C1/M1 combo
    denon avr 3802
    lg bd650 bluray
    denon dvd2900
    jbl s312II
    jbl scenterII
    jbl s36II
    jbl s36II
    2 x rocket ulw-10
    music room
  8. #7
    gholt is offline Full Audioholic gholt is considered a mentor
    Join Date
    Jun 2009
    Posts
    341
    Thanks Given
    45
    Thanks Received
    31
    Default
    I have an old set of Boston Acoustics A-150s. The bass was sounding weak, and I called them to see if they still had parts for the speaker. For $30 each side I got new woofers still in paper cone. Not sure if the mids are still working, maybe they should be sent to the speaker company for help.
  9. #8
    AJinFLA is offline Banned AJinFLA is quite helpful
    Join Date
    Mar 2009
    Location
    Tampa
    Posts
    445
    Thanks Given
    7
    Thanks Received
    91
    Default
    Hi Gene,
    It's been eons since I was last there, but doesn't http://www.speakerex.com/ on Hillsborough Ave do the same type work as well?
    cheers,
    AJ
  10. #9
    gene's Avatar
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,818
    Thanks Given
    819
    Thanks Received
    2,401
    Default
    Hi Gene,
    cheers,
    AJ
    I've heard of them but I never had any dealings. I am sure they do similar work as Simply Speakers. Its cool to see Vintage stuff being reconditioned. Sometimes "they don't build it like they used to" is very applicable with successor speaker lines from the same company.
    Gene DellaSala
  11. #10
    E-Lab is offline Audiophyte E-Lab is a forum member in good standing
    Join Date
    Mar 2009
    Posts
    4
    Thanks Given
    1
    Thanks Received
    0
    Default
    I just sent my JBL 4408 woofers to the factory to be reconed about 6 months ago. They probably only needed to be refoamed, but I figure with a new slinky, cone, surround and spider that they will be good to go for another 19 years. I think the bill was close to $250 or more, but I can't find any cracker jack speakers to beat them for that. Good enough for Christmas music...that's all the action they get.
    They are probably due for a cap. swap too.
    It looks like that one photo of their shop shows the 2-way Altec Lancing speakers from the late 80's or early 90's. I thought they looked neat when I was in college...I hope I don't become a speaker pack rat.
    Thanks for the tip!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
