Page 4 of 45 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 449
Thread: Simple 12" Infinity Kappa VQ MidQ Plans
  1. #31
    ParadigmDawg's Avatar
    ParadigmDawg is offline Audioholic Warlord ParadigmDawg should be listened to
    Join Date
    Nov 2006
    Location
    Hiding from Alex
    Posts
    9,309
    Thanks Given
    2,424
    Thanks Received
    2,630
    Default
    Ok guys, I am pretty certain that I am going to sale the Servo and try a couple of these. Any downside to this plan?
    A bunch of Paradigm stuff, a big sub, a few amps and 3 plasma's...Panny of course...
  2. #32
    WmAx's Avatar
    WmAx is offline Audioholic Samurai WmAx should be listened to
    Join Date
    Apr 2004
    Posts
    5,177
    Thanks Given
    3
    Thanks Received
    1,353
    Default
    Quote Originally Posted by Greg Gable View Post
    Let's see....
    1. Far superior performance...
    2. You get a valuable learning experience...
    3. Lower cost than a commercial sub of far lower quality...
    I can't seem to find the negatives......
    Oh, wait.... there is no warranty on your own built product. Is that a problem?
    -Chris
    Dedicated to improving the real[quantifiable] parameters of sound reproduction.
  3. #33
    Join Date
    Nov 2006
    Location
    Hiding from Alex
    Posts
    9,309
    Thanks Given
    2,424
    Thanks Received
    2,630
    Default
    Cancel the "valuable learning experience", you know who will be doing the dirty work.
    Quote Originally Posted by WmAx View Post
    Let's see....
    -Chris
  4. #34
    jboogie is offline Junior Audioholic jboogie is a forum member in good standing
    Join Date
    May 2008
    Posts
    61
    Thanks Given
    7
    Thanks Received
    4
    Default A million thanks
    I will be starting my build of these starting on Wed. I am going to integrate a plate amp, but that should have minimal effect on the overall plan.
    (For those that saw some of my other ?'s and replies, I have decided to keep the plate amp and simply upgrade at a later time.)
    I will post with any progress or insights.
    Again, thank you so much!
  5. #35
    Haoleb's Avatar
    Haoleb is offline Audioholic General Haoleb should be listened to
    Join Date
    Jul 2006
    Location
    Maine
    Posts
    1,448
    Thanks Given
    27
    Thanks Received
    327
    Default
    Where are you going to mount the plate amp? There is little room inside the sub for something like that. If you put it on the back you'll be blocking the airflow in the port (depending on how deep it is)
  6. #36
    WmAx's Avatar
    Join Date
    Apr 2004
    Posts
    5,177
    Thanks Given
    3
    Thanks Received
    1,353
    Default
    DO NOT INSTALL the plate amp in any part of a port wall.
    -Chris
  7. #37
    Djizasse's Avatar
    Djizasse is offline Senior Audioholic Djizasse is looking for a job at AH
    Join Date
    Feb 2008
    Location
    Lisbon, Portugal
    Posts
    727
    Thanks Given
    617
    Thanks Received
    156
    Default
    I've seen this on sale:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=370065635446
    It refers to the "INFINITY KAPPA SERIES PERFECT 12D VQ" (notice the "D" after the 12).
    I consulted the infinity site but was unable to understand the differences between the "12 VQ" and the "12D VQ" versions.
    Is it still appropriate to this project?
    My home office - WIP - [X360 Elite] - [Zalman TNN-500AF with E6600/4Gb] - [4x Tannoy Reveal 6 + Reveal 66] - [Yamaha RX-V861] - [Samsung LE32A656] - [Behringer EP2500 + DCX 2496 + Infinity Kappa VQ gueto build]
    Living Room - [Toshiba EP35] - [Marantz SR-6003] - [2x Monitor Audio RS6 + Monitor Audio RS LCR + 2x Monitor Audio RSFX] - [Samsung LE52A656]
  8. #38
    WmAx's Avatar
    Join Date
    Apr 2004
    Posts
    5,177
    Thanks Given
    3
    Thanks Received
    1,353
    Default
    Quote Originally Posted by Djizasse View Post
    The 'D' stands for dual-voice coil. The one that all of the cabinet designs is given for here is the single-voice coil version.
    -Chris
  9. The Following User Says Thank You to WmAx For This Useful Post:
    Djizasse (07-07-2008)
  10. #39
    gus6464 is offline Audioholic Samurai gus6464 is looking for a job at AH
    Join Date
    May 2007
    Posts
    2,302
    Thanks Given
    144
    Thanks Received
    388
    Default
    Not to hijack the thread, but if one wanted less extension (25Hz max) would it possible to put these drivers in a smaller sealed enclosure?
    Panasonic TH-50PX75U Plasma
    Yamaha RX-V661
    Mirage Omni 550
    Mirage Omni C150
    Mirage Omni 150
    Sony SA-W2500 (until svs or hsu sub)
    Sony Playstation 3
    Toshiba HD-A3
    Nintendo Wii
    Office system (2ch only)
    Dali Ikon 2
    Rega Planar 2 w/ AT440MLa cart
    Rolls Bellari tube phono preamp
    Sony STR-DE675 AVR
    Samsung DVD-HD841 (sacd player)
  11. #40
    avaserfi's Avatar
    avaserfi is offline Audioholic Ninja avaserfi should be listened to
    Join Date
    Mar 2007
    Location
    College Station, TX
    Posts
    3,295
    Thanks Given
    154
    Thanks Received
    909
    Default
    Quote Originally Posted by gus6464 View Post
    This would be possible with the correct driver/amplifier/cabinet integration. The largest loss with using a sealed cabinet would be increased distortion, maximum SPL and low frequency response. It is important to note that a driver capable of being equalized with minimal distortion down to 25Hz in a sealed cabinet will be very expensive.
    A cheaper option would be designing a ported cabinet that uses utility port. That is the port is not sufficiently designed to eliminate port compression (so it is smaller), but compression will occur out of the intended passband due to tuning frequency and DCX integration.
    Andrew
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
