Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Video: Installing Surround Sound Speakers
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Video: Installing Surround Sound Speakers
    We know you're out there. Yes, you. The guy who bought that 5.1 surround sound system in Christmas of 2006 but still hasn't hooked up the rear speakers. It's too hard, you say! There, there, we feel your pain. But it's not really all that bad. In fact, we decided to put our money - uh, make that our bodies - where our mouths are. Audioholics takes itself up into the attic... in the middle of summer... in Florida... to help YOU learn how to install your surround sound speakers. Yeah, we love ya.
    Discuss "Installing Surround Sound Speakers" here. Read the article.
  2. The Following 4 Users Say Thank You to admin For This Useful Post:
    BoredSysAdmin (10-21-2012),Dolby CP-200 (09-27-2007),k_lewis (04-26-2011),Matt34 (09-30-2007)
  3. #2
    Adam's Avatar
    Adam is online now Audioholic Jedi Adam should be listened to
    Join Date
    Jul 2006
    Location
    Tucson, Arizona
    Posts
    26,516
    Thanks Given
    7,573
    Thanks Received
    9,125
    Default
    Excellent! Informative, funny...good stuff.
    The section on the wall plate for the speaker jacks will come in handy for me because I'll be installing some soon. I thought that I'd need a wall box based on some other things that I'd read, but it looks like you just screwed the cover plate over a hole in the wall. That's easier for me to do!
    Thanks for the video!
    Mains and Surrounds: NHT 1.5s, Center: NHT AudioCenter-1, Subs: SVS PC13-Ultra, SB13-Ultra, Receiver: Pioneer Elite VSX-23, Amps: Emotiva RPA-1, POS-1, Display: Panasonic TC-P50G10
  4. #3
    Clint DeBoer's Avatar
    Clint DeBoer is offline Administrator Clint DeBoer should be listened to
    Join Date
    Jul 2002
    Location
    Lakeland, Florida, United States
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default
    Just check your local codes - we're not responsible for any violations, fires, etc... lol.
    Clint DeBoer
    Editor in Chief
    Audioholics
  5. #4
    lonwa is offline Enthusiast lonwa is a forum member in good standing
    Join Date
    Sep 2003
    Posts
    15
    Thanks Given
    0
    Thanks Received
    0
    Default Fire Breaks?
    Great video, I will be wiring up my new house shortly.
    One question I have that was not addressed in the video, is how do you get the cables through a fire break in the wall (i.e. when its halfway down the wall)?
    Thanks for the help,
    Lonwa
  6. #5
    MDS
    MDS is offline Audioholic Spartan MDS should be listened to
    Join Date
    Oct 2004
    Location
    Austin, TX
    Posts
    6,683
    Thanks Given
    106
    Thanks Received
    763
    Default
    Quote Originally Posted by lonwa View Post
    With a giant drill bit or you can cut out a piece of the drywall near the firebreak and then drill your hole in the firebreak and repatch the drywall.
  7. #6
    MDS
    Join Date
    Oct 2004
    Location
    Austin, TX
    Posts
    6,683
    Thanks Given
    106
    Thanks Received
    763
    Default
    Quote Originally Posted by Adam View Post
    You can certainly do it that way if you want but I think it is cleaner with a retro-ring. The retro-ring has dog legs that clamp to the drywall and then you screw the wall plate into it.
    I am not a fan of the Leviton binding posts. For 12/2 they may not be so bad because the wire is thick but the tiny little set screw does not hold 16/2 very well. I bought wall plates with binding posts from PartsExpress and IMO they are much better. They have binding posts on both sides and you can either use bananas on the back or bare wire but you screw down the binding post the same way you would on the back of your receiver.
    One other thing I'd suggest, although most people probably wouldn't bother. While you are up in the attic sweating buckets, use a Sharpie marker and write 'left surround' or whatever on the joist above the wire you just ran. If you ever have to go up there again you won't have to do the wire trick to locate it again.
  8. The Following User Says Thank You to MDS For This Useful Post:
    Adam (09-30-2007)
  9. #7
    ParadigmDawg's Avatar
    ParadigmDawg is offline Audioholic Warlord ParadigmDawg should be listened to
    Join Date
    Nov 2006
    Location
    Hiding from Alex
    Posts
    9,309
    Thanks Given
    2,424
    Thanks Received
    2,630
    Default
    That was a great, informative video with good use of humor. I think this will show people that it is easier than they think. I was nervous when I did my first in-wall/attic wiring job but it is much easier than it seems.
    A bunch of Paradigm stuff, a big sub, a few amps and 3 plasma's...Panny of course...
  10. #8
    Join Date
    Jul 2002
    Location
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default
    I would HIGHLY recommend people build on what they see here. Those retro rings are a great example. I typically use those, or aftermarket retro-boxes in almost every install I do. In this case I 'rednecked' it for the video as I didn't have one handy.
    Clint DeBoer
    Editor in Chief
    Audioholics
  11. #9
    Matt34's Avatar
    Matt34 is online now Moderator Matt34 should be listened to
    Join Date
    Jul 2005
    Location
    Colorado
    Posts
    6,244
    Thanks Given
    1,385
    Thanks Received
    2,601
    Default
    Great video! I'm going to sit down and watch the "Best of CEDIA" tonight. I've tried to watch it but haven't had any time.
    Couple of suggestions:
    I think perhaps we need a section dedicated to just videos, it would be easy to keep track of them.
    Make them downloadable like the podcasts, I've watched the first 10 minutes of the CEDIA video but wasn't able to finish it, now I have to start from the beginning.
  12. #10
    Adam's Avatar
    Join Date
    Jul 2006
    Location
    Tucson, Arizona
    Posts
    26,516
    Thanks Given
    7,573
    Thanks Received
    9,125
    Default
    Quote Originally Posted by Matt34 View Post
    Make them downloadable like the podcasts...
    I'll second that suggestion!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
