Originally Posted by
Shadow_Ferret
Wow. $1200? Why can I get a good UPS unit for my computer for a 6th that price?
Most computer grade UPS have square/modified square sine wave output waveforms. Although perfectly acceptable for most computer based applications, there are some equipment that will perform poorly or simply not work at all.
Pure sine wave UPSes use better quality inverters to regenerate an AC waveform with utmost fidelity.
Factors such VA rating, rated current, etc. that are also important and affect price as you go to higher application needs. That is why it's important to size your UPS accordingly for its intended use.
KL
Blu-Ray Player : DMP-BD65
CD Player : Sony CDP-C225
Receiver : Harman Kardon AVR 235
Remote Control : Logitech Harmony 650
Speakers: Boston Acoustics CS 260 II Towers, CS 225C II center
Subwoofer : Paradigm PDR-10
TV : Panasonic TC-54PS14
