Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Speaker hiss with XPA-5
  1. #1
    Rblaster85 is offline Enthusiast Rblaster85 is a forum member in good standing
    Join Date
    Dec 2012
    Posts
    12
    Thanks Given
    0
    Thanks Received
    0
    Default Speaker hiss with XPA-5
    Hey all, I purchased an XPA-5 to power my home theater I was planning on running my fronts center and surrounds off of it and my rear surrounds off my reciever. I have:
    RF-82ii
    RC-52ii
    Rs-52ii
    I hooked everything up and everything sounds great, Much more powerful, the speakers sounded much better than when connected to the SR5007. My problem is that when I pause a movie or listen to 2Channel music, There is a Hiss coming from my RS-52ii which I can hear from my listening position. When I put my ear to my center and tower speakers there is a hiss as well, however I cannot hear it from my listening position. To solve this problem I just hooked the RS-52 back up to my receiver.
    With all of the speakers connected to the XPA-5 the distortion issue I was having with COD black ops 2 was almost completely eliminated. However with the rear speakers hooked up to only my receiver the problem still exists.
    I have also disconnected everything from the amp and just had the speakers connected, the hiss is still there so I know that its not coming from another component.
    Does anyone have any suggestions on how to eliminate the hiss or is it just something I have to live with? I have a limited knowledge of electrical engineering, but I was thinking if I hooked up a resister in line with the speaker cable this would increase the resistance and make the speaker less sensitive? not sure how that would effect the components of the speaker though.
    Any advice is appreciated.
  2. #2
    Steve81's Avatar
    Steve81 is offline Audioholic Samurai Steve81 should be listened to
    Join Date
    Aug 2012
    Location
    A long time ago in a galaxy far, far away....
    Posts
    2,075
    Thanks Given
    845
    Thanks Received
    997
    Default
    Emotiva to my knowledge doesn't recommend pairing the big XPA's with higher sensitivity loudspeakers as their voltage gain is higher than average at 32dB. However, I have heard of people getting in line attenuators over at the Klipsch forums to alleviate the problem. Barring that, return the XPA-5 and get an amplifier with lower gain. 29dB is the norm, and what Emotiva seems to be moving to with the UPA line, XPA-X00, and XPR line, and I didn't have any problems with hiss/noise pairing the XPA-200 with a pair of RF-5s.
  3. The Following User Says Thank You to Steve81 For This Useful Post:
    Irvrobinson (03-15-2013)
  4. #3
    AcuDefTechGuy's Avatar
    AcuDefTechGuy is online now Audioholic Overlord AcuDefTechGuy should be listened to
    Join Date
    Jul 2007
    Location
    Krypton
    Posts
    13,590
    Thanks Given
    3,377
    Thanks Received
    3,032
    Default
    Buy an ATI amp, which is dead silent.
    REVEL SALON2 . B&W 802D2 . KEF 201/2 (6) . LINKWITZ ORION3 . TAD 2201 . DYNAUDIO X32 . FOCAL 826V . ATC SCM7 . PHILHARMONIC 3 . FUNK 18.0 (2) . RBH SX-1010N (2) . VELODYNE SC600 (4) . PIONEER MM301 (8) . DENON AVP-A1HD/AVR-5308/AVR-3312/DVD-3800BD . ATI 3005/3002/2004/6012 . BENQ W6000 . ADCOM GFS-600 . APPLE TV . KIMBER KABLE 8PR
    My System Photo . My System Video
  5. #4
    FirstReflection is offline Audioholic General FirstReflection should be listened to
    Join Date
    Aug 2008
    Posts
    1,237
    Thanks Given
    68
    Thanks Received
    812
    Default
    Quote Originally Posted by AcuDefTechGuy View Post
    Not quite DEAD silent, Acu. If I physically press my ear against my speakers' tweeters, I can make out an extremely soft hiss from my AT1805...
    In actual seriousness, though, you might actually have a slightly defective amp. It's a possibility. A forum member a few months back had a similar situation with his XPA-5. Three of the channels produced a normal, very soft hiss that he could only make out from a few inches away. That's perfectly normal for most amps. But two of the channels produced an audible hiss that he could hear from his seat. That is NOT normal, and after finally getting a replacement from Emotiva, he now has a properly functioning XPA-5 that is silent at seating distance, and only produces a soft hiss that can only be heard if he's within a few inches of the speakers.
    Try connecting just one speaker, and connect that one speaker to each output on your Emotiva amp. Try to discern if one or two of the channels are significantly louder than the others. If they are, then you have a couple of defective boards, and you should be firm with Emotiva until they send you a replacement.
    I know that Emotiva's customer service is less than stellar sometimes. Seems to be one guy named Vincent who causes all the problems. Just ask to speak with Lonnie Vaughn and deal with him right from the get go. He'll take care of you if it really is a defective amp.
    Again, a very slight hiss IS normal. But it should be very quiet or completely inaudible from your seat. And particularly if one or two channels are louder than the others. That's a sure sign of something being wrong with the amp. Talk to Lonnie and get a replacement A 100% properly functioning XPA amp is darn good, and should be very pleasing in all aspects.
  6. The Following User Says Thank You to FirstReflection For This Useful Post:
    KEW (03-16-2013)
  7. #5
    sgtjim is offline Audiophyte sgtjim is a forum member in good standing
    Join Date
    Feb 2013
    Location
    Tullahoma Tennessee
    Posts
    6
    Thanks Given
    1
    Thanks Received
    0
    Default
    I have an XPA-5 and I have zero hiss from any of my speakers. There are many issues that could cause a hiss, speaker cable, ground, circuit, snake in the wall so you will just have to trail and error until you remedy the issue.
  8. #6
    Join Date
    Jul 2007
    Location
    Krypton
    Posts
    13,590
    Thanks Given
    3,377
    Thanks Received
    3,032
    Default
    Quote Originally Posted by FirstReflection View Post
    Really?
    My AT3005, AT3002, & AT2004 are absolutely dead silent with my ear pressed against the speakers and the Denon AVR master volume all the way up (w/o source playing).
    I've heard from other members that the AT1800 & other models are also dead silent. But apparently not all cases then.
  9. #7
    MidnightSensi2 is offline Full Audioholic MidnightSensi2 should be listened to
    Join Date
    Oct 2010
    Posts
    473
    Thanks Given
    305
    Thanks Received
    182
    Default
    Really?
    Depends on the sensitivity of the speaker and also how the amplifier is gain staged. Yours might be gain staged properly and/or your speakers less sensitive. Usually proper gain staging is the more important of the two.
    To OP:
    I have 101/db-w speakers and have only a little hiss if I put my ears right up to them. So, we should be able to find a solution to your problem. Let's troubleshoot...
    Make sure the levels out of the receiver are hot (not clipping, but, you should be watching a movie where 0 is reference level - audioholics has howtos on how to set this up). Your amp is fixed gain, so, that will allow you to turn the input attentuators down and reduce the noise of the amplifier. Since you are not powering all your speakers off similar amps, you likely will have to adjust levels a bit in the receiver. Don't worry, lowering the input attentuators does not prevent the amp from reaching full power.
    H/T: JTR T8 LCRs, M&K S150 surrounds, Danley CS30 subs, Onkyo Professional pre-pro, dbX dsp, Crest & Crown Amps, Epson Pro projector, Auralex & GIK treatments (Sources: WD Live, PS3, Technics 1200, AppleTV)
    2.1 Studio: Bag End PM6s & Infra Pro 12", Focusrite AD-DA, Beyerdynamic DT770s, Auralex & GIK treatments (Sources: MacBook Pro 15" Retna w/ Adobe Production Suite & Cubase)
  10. #8
    Join Date
    Jul 2007
    Location
    Krypton
    Posts
    13,590
    Thanks Given
    3,377
    Thanks Received
    3,032
    Default
    So the best thing to do is probably to decrease the speaker channel levels in the AVR to the reference 75dBC on the SPL meter, or just run Audyssey?
  11. #9
    ski2xblack's Avatar
    ski2xblack is offline Senior Audioholic ski2xblack should be listened to
    Join Date
    Mar 2005
    Location
    Colorado high country
    Posts
    578
    Thanks Given
    62
    Thanks Received
    199
    Default
    It concerns gain and sensitivity, as mentioned above. Audyssey is another kettle of fish.
    A Discussion About Idle Hiss
  12. #10
    Irvrobinson is online now Audioholic Field Marshall Irvrobinson should be listened to
    Join Date
    Dec 2004
    Posts
    1,583
    Thanks Given
    309
    Thanks Received
    754
    Default
    Quote Originally Posted by ski2xblack View Post
    Of course this dealer would say SNR is unimportant, they push vacuum tube amps. Hiss drives me nuts, I want a dead silent background if I'm buying a premium amp.
    As for the Emotiva, I agree with Steve81, this is probably a component matching issue. I think Emotiva made an understandable but controversial decision to push their input sensitivity up so high. They probably did it because of weakling AVR pre-out driver circuits, but that sensitivity has all sorts of ramifications with high quality front ends. I further agree with him that line attenuators are probably a good solution; I use them with my subwoofer. Parts Express carries attenuators for balanced and single-ended cables at reasonable prices.
    "I've always enjoyed the spectacle of second-rate minds freaking out over a first-rate reality..." Peter Aczel
  13. The Following User Says Thank You to Irvrobinson For This Useful Post:
    Steve81 (03-15-2013)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
