Results 1 to 6 of 6
Thread: audio receiver with voltage converter
  1. #1
    ab_enthusiast is offline Audiophyte ab_enthusiast is a forum member in good standing
    Join Date
    Jun 2012
    Posts
    2
    Thanks Given
    0
    Thanks Received
    0
    Default audio receiver with voltage converter
    Currently I am overseas and my Marantz SR6003 works here on 240V.
    I am shortly moving to US and was considering using it in US with a voltage converter.
    What are the Pros & Cons of this ? Appreciate your advice on this.
  2. #2
    TLS Guy's Avatar
    TLS Guy is offline Audioholic Warlord TLS Guy should be listened to
    Join Date
    Oct 2007
    Location
    Benedict MN
    Posts
    9,876
    Thanks Given
    865
    Thanks Received
    4,017
    Default
    Quote Originally Posted by ab_enthusiast View Post
    Unless you are in an NTSC area then voltage conversion is the least of your worries, So it depends on where you are oversees, whether your plan is possible or not. If you are in Europe, your receiver will not work in the US.
    Marantz DV 9600 Oppo BD-83 Marantz AV 8003 Quad current dumping amps X 7 Direct TV HD 20 HD DVR Carter audio workstation RME Fireface 800 Fujitsu 50XHA40 Front left and right Carter dual transmission line studio monitors MK II. Center Carter coaxial transmission line center speaker Rear Carter NFM-1s Center backs Carter dual transmission line studio monitors MK I. My system: - http://mdcarter.smugmug.com/gallery/...27077317_Pufg7
  3. #3
    Join Date
    Jun 2012
    Posts
    2
    Thanks Given
    0
    Thanks Received
    0
    Default
    Quote Originally Posted by TLS Guy View Post
    I am in a PAL area - Singapore. Does HDMI respect PAL/NTSC ? I thought PAL/NTSC was an analog standard
  4. #4
    TLS Guy's Avatar
    Join Date
    Oct 2007
    Location
    Benedict MN
    Posts
    9,876
    Thanks Given
    865
    Thanks Received
    4,017
    Default
    It is analog and digital at the screen. You will not get a picture on a US TV, nor will a US DVD or BD player work with it, although some you can switch to PAL, but not the TVs.
  5. The Following User Says Thank You to TLS Guy For This Useful Post:
    ahblaza (06-17-2012)
  6. #5
    Adam's Avatar
    Adam is offline Audioholic Jedi Adam should be listened to
    Join Date
    Jul 2006
    Location
    Tucson, Arizona
    Posts
    26,518
    Thanks Given
    7,578
    Thanks Received
    9,125
    Default
    That's not universally true for video as some TVs support both formats, though. For RCA and S-Video connections, it can be an issue, but I'm not convinced that it applies to HDMI as strictly. Why do you say U.S. TVs and players won't work with the Marantz HDMI connections?
    Mains and Surrounds: NHT 1.5s, Center: NHT AudioCenter-1, Subs: SVS PC13-Ultra, SB13-Ultra, Receiver: Pioneer Elite VSX-23, Amps: Emotiva RPA-1, POS-1, Display: Panasonic TC-P50G10
  7. #6
    TLS Guy's Avatar
    Join Date
    Oct 2007
    Location
    Benedict MN
    Posts
    9,876
    Thanks Given
    865
    Thanks Received
    4,017
    Default
    Quote Originally Posted by Adam View Post
    PAL and NTSC have different and fundamental differences.
    He will need a converter like this, but results my be unreliable because of DRM issues.
    In addition the FM pre/emphasis and de/emphasis is different from region to region.
    I never advise trying to use a receiver in a different region from what is was designed for.
    You are far better off selling it and buying new after the move. That is by far the cheapest and best solution.
  8. The Following User Says Thank You to TLS Guy For This Useful Post:
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
