Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Need DAC Advice Please ^_^
  1. #11
    TLS Guy's Avatar
    TLS Guy is offline Audioholic Warlord TLS Guy should be listened to
    Join Date
    Oct 2007
    Location
    Benedict MN
    Posts
    9,876
    Thanks Given
    865
    Thanks Received
    4,017
    Default
    Quote Originally Posted by jonnythan View Post
    But you're summing the output of the speaker's preamp. The left speaker has stereo inputs that feed an internal 2-channel amp. The amp also has stereo preouts.
    I know, but if those outputs are not buffered you will get mono.
    To be certain you would have to see the circuit. However the overwhelming likely hood is that those outputs are not buffered.
    Marantz DV 9600 Oppo BD-83 Marantz AV 8003 Quad current dumping amps X 7 Direct TV HD 20 HD DVR Carter audio workstation RME Fireface 800 Fujitsu 50XHA40 Front left and right Carter dual transmission line studio monitors MK II. Center Carter coaxial transmission line center speaker Rear Carter NFM-1s Center backs Carter dual transmission line studio monitors MK I. My system: - http://mdcarter.smugmug.com/gallery/...27077317_Pufg7
  2. #12
    Grador is offline Audioholic General Grador is looking for a job at AH
    Join Date
    Feb 2012
    Location
    SoCal
    Posts
    1,266
    Thanks Given
    185
    Thanks Received
    327
    Default
    I believe what TLS Guy is saying is that if the speaker's internal amplifier is not well designed they can be driven from the output jacks. If this is the case putting a Y-cable on the left and right outputs could allow them to essentially drive each other which would end up summing the signals to mono internal to each speaker.
    Hope this is correct and clears things up a little.
    HT: Samsung LN32B460 32" LCD (greyscale calibrated) | AVR: Yamaha RX-V765 | L/R: Emp E55Ti | C: Paradigm Center 1 | Rears: Sony Junk | SW: Klipsch RW-10d miniDSP | Sources: Acer Revo Ion running XBMC with mySQL library server and 4 TB HDD, PS3, Technics SL-Q2 TT | 2x Aura Pro Bass Shakers
    Bookshelf: Yamaha RX-V992 | Paradigm Mini Monitors
    Shelved for now: Paradigm 11 SE Deluxe
  3. #13
    TLS Guy's Avatar
    Join Date
    Oct 2007
    Location
    Benedict MN
    Posts
    9,876
    Thanks Given
    865
    Thanks Received
    4,017
    Default
    Quote Originally Posted by Grador View Post
    That is exactly what is most likely to happen. That is why sub manufacturers put on left and right inputs, as this is the usual situation and the sub has the buffer amps. A sub with only one line input can only be powered from an LFE input, a buffer or dual channel crossover.
  4. #14
    TLS Guy's Avatar
    Join Date
    Oct 2007
    Location
    Benedict MN
    Posts
    9,876
    Thanks Given
    865
    Thanks Received
    4,017
    Default
    The OP can do a simple test to see if the A5 outputs are buffered. Connect the two line outs together and then provide input to only one speaker.
    If sound only comes out of that speaker the outputs are buffered, if sound come out of both speakers they are not buffered.
  5. #15
    mmbuckwa is offline Audiophyte mmbuckwa is a forum member in good standing
    Join Date
    Apr 2012
    Posts
    4
    Thanks Given
    0
    Thanks Received
    0
    Default
    Hello, this is my first post and I have the Audioengine A5 speakers hooked up to my desktop and I love them. I looked into DACs a month ago and almost got the Audioengine D1 but read the audio blog over at cnet and they recommended the Fiio E10 dac over the audioengine. I ended up getting that because of this and the fact that it cost only half the price of the D1. It sounds better than without it but I have no way of knowing myself how it compares to the Audioengine. The Fiio does have a bass boost switch that I keep turned on and it provides all the bass I need with out a subwoofer.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
