Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
Thread: Audioholics - Please help plan our next round of upgrades.
  1. #31
    mtrycrafts's Avatar
    mtrycrafts is offline Audioholic Overlord mtrycrafts should be listened to
    Join Date
    Aug 2004
    Posts
    14,777
    Thanks Given
    142
    Thanks Received
    1,092
    Default
    Quote Originally Posted by somesnapper View Post
    Hello Audioholics,
    I’d like to upgrade my home theater! The first time around I did not research many brands and may have limited my options. It’s been a few years since I’ve upgraded my speakers so I’d like to “do it right” this time.
    Current Equipment:
    Aperion Audio 6T and 5C front stage. 4B Heights and Rears. No sub.
    Denon 2312ci, WDTV/PS3 as Media Source.
    Room:
    12x20, but biased to one side with high ceilings (See screenshot below)
    Apartment Woes:
    Upgrade Plan:
    I would highly recommend a stand alone house, not another apartment on the ground floor. The sub will be an issue there as well, especially if you like reference levels. And, preferably a house with lots of space between you and the neighbors. And a house with accommodating room for your setup.
  2. #32
    somesnapper is offline Audioholic Intern somesnapper is a forum member in good standing
    Join Date
    Mar 2012
    Posts
    44
    Thanks Given
    7
    Thanks Received
    0
    Default
    Yes, that's high on my list too!
  3. #33
    Join Date
    Mar 2012
    Posts
    44
    Thanks Given
    7
    Thanks Received
    0
    Default
    Besides Philharmonics?
    What would be a great front stage (LCR) for less than $3000
    Ascends Horizon Center and Towers are on my list and I will demo it next week.
    What other brands should I look at?
    Salk Center looks too small and probably wouldn't be much of a upgrade over what I have now.
  4. #34
    AcuDefTechGuy's Avatar
    AcuDefTechGuy is online now Audioholic Overlord AcuDefTechGuy should be listened to
    Join Date
    Jul 2007
    Location
    Krypton
    Posts
    13,581
    Thanks Given
    3,377
    Thanks Received
    3,029
    Default
    Key thing is comparing the Phil/Salk/Ascend to your Aperion.
    If it is a clear improvement to you, I think any of these 3 will be good.
    If it is not a clear improvement, then you are already good and don't need to spend another dime.
    NHT also gives you free 30-day trial free shipping both ways. Amazon direct does too. Amazon sells NHT & KEF. Might try the KEF Q900 & Q200C.
    http://www.amazon.com/KEF-Q200cBL-Ce...3120101&sr=8-1
    Won't be same quality standard as the Philharmonic speakers, though.
    REVEL SALON2 . B&W 802D2 . KEF 201/2 (6) . LINKWITZ ORION3 . TAD 2201 . DYNAUDIO X32 . FOCAL 826V . ATC SCM7 . PHILHARMONIC 3 . FUNK 18.0 (2) . RBH SX-1010N (2) . VELODYNE SC600 (4) . PIONEER MM301 (8) . DENON AVP-A1HD/AVR-5308/AVR-3312/DVD-3800BD . ATI 3005/3002/2004/6012 . BENQ W6000 . ADCOM GFS-600 . APPLE TV . KIMBER KABLE 8PR
    My System Photo . My System Video
  5. #35
    Join Date
    Mar 2012
    Posts
    44
    Thanks Given
    7
    Thanks Received
    0
    Default
    Thanks guys. I've decided against Philharmonics (no offence).
    Thanks for the suggestion on KEF and Amazon. I'm looking at the KEFQ900 and 600 center and both speakers look very capable. I'm not sure how they fare in performance compared to my current Aperions. I'm looking for reviews and feedback on those now.
  6. #36
    Join Date
    Mar 2012
    Posts
    44
    Thanks Given
    7
    Thanks Received
    0
    Default
    My Aperion 6T’s can play down to 32hz and I don’t get any complaints watching movies at 93dB (with spikes to 103dB).
    Based on the fact that I have old floors and neighbors…I really can’t play much to “Deeper” in terms of bass. My floors resonate into the neighbor’s home at sub 30hz right now. However in November I plan on moving.
    I’m looking for a really large front stage/center (without harsh tweets)…my options are:
    1) Bookshelf’s+ big center speaker+ and a sub with bass extension filters
    2) towers (that play as deep as 30hz)+big center+NO sub sub woofer
    Both options would cost around the same (2-3k). Herm… Options. Thoughts?
    I’m also treating my room this weekend . Hopefully it improves “clarity at lower volumes”
  7. #37
    benbodtke is offline Junior Audioholic benbodtke is gaining some recognition
    Join Date
    Mar 2012
    Posts
    88
    Thanks Given
    12
    Thanks Received
    19
    Default
    The towers sure do look a lot better. You can get some really nice ones in the 2-3K range.
  8. #38
    Join Date
    Mar 2012
    Posts
    44
    Thanks Given
    7
    Thanks Received
    0
    Default
    I would only have 2k for towers here...
  9. #39
    Join Date
    Mar 2012
    Posts
    88
    Thanks Given
    12
    Thanks Received
    19
    Default
    CBT36 Line Array Speaker Kit Pair 301-980
  10. #40
    fuzz092888's Avatar
    fuzz092888 is online now Audioholic Samurai fuzz092888 should be listened to
    Join Date
    Feb 2012
    Location
    A dream within a dream.
    Posts
    2,814
    Thanks Given
    1,181
    Thanks Received
    1,319
    Default
    The CBT is a great kit, but depending on how you finish it you'll over 2 grand, plus the amount of time it takes to put it all together. They're a great project, but not necessarily for someone who wants performance now. If you've got the time, definitely.
    How many of the suggestions have you gone out and auditioned? Thats really the only way to come to any sort of definitive answer to your questions. Get out there and listen to some of these speakers and maybe you have. I just think if you had spent some time with these speakers we would have heard, yes I liked this and why, no I didn't like this.
    Reviews and suggestions are only part of this whole process, subjective listening by you is what really matters. Specs and other people opinions will get you so far and help you weed out the garbage, but hearing is believing so to speak.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
