Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Emotiva UMC-200 DAC vs Denon 3313
  1. #1
    shizam1 is offline Audiophyte shizam1 is a forum member in good standing
    Join Date
    Mar 2013
    Posts
    3
    Thanks Given
    0
    Thanks Received
    0
    Default Emotiva UMC-200 DAC vs Denon 3313
    Looking for some thoughts/advice... I currently have a Denon 2310 that I use to drive Aperion Verus Grand Towers & Center.
    That receiver doesn't support passing 3D... and I now have a 3D projector and blu-ray player so I want to try that functionality out.
    Anyhow, a couple of choices are:
    Denon 2313 - pretty much same as what I have, just has 3D support
    Denon 3313 - a bit more power, possibliy better amplifier, and pre-outs
    Emotiva UMC-200 & XPA-5 - 3d and oodles of power.
    The only thing turning me off to the Emotiva UMC-200 is the review on this site that said the DAC wasn't that good compared to the Oppo DAC. So... I'm wondering how it compares to the ones in the Denon receivers?
  2. #2
    j_garcia's Avatar
    j_garcia is offline Seriously, I have no life. j_garcia should be listened to
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,290
    Thanks Given
    1,664
    Thanks Received
    3,807
    Default
    The Oppo costs twice the price of the UMC-200 and uses some pretty exemplary DACs. The review isn't saying the DACs in the UMC aren't good, they just aren't better than the ones in the Oppo. Gene pretty much said you will have a hard time finding anything that sounds better than the Oppo right now in his opinion.
    HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
    System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
    Are you sure which side of the glass you are on?
  3. #3
    Join Date
    Mar 2013
    Posts
    3
    Thanks Given
    0
    Thanks Received
    0
    Default
    Thanks for the response. Any reason not to go with the Emotiva solution vs Denon 3313 if I only have HDMI sources?
  4. #4
    j_garcia's Avatar
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,290
    Thanks Given
    1,664
    Thanks Received
    3,807
    Default
    The 3313 won't have a better amp section than the XPA-5, so I'd choose the setup with the amp for speakers like that. If you get a lower Denon with pre-outs, you could still have a solid setup though, since you could still add an amp. I don't have experience with the Verus line, but the Grand towers are listed as 92dB sensitive and 6 Ohm, so a receiver might be able to handle them fine if you don't have a massive room and depending on your listening levels. Though I don't think SQ will be a significant difference between the two, just in terms of amplification, I don't think the Denon is going to give you the same performance for the price.
  5. #5
    Steve81's Avatar
    Steve81 is offline Audioholic Samurai Steve81 should be listened to
    Join Date
    Aug 2012
    Location
    A long time ago in a galaxy far, far away....
    Posts
    2,073
    Thanks Given
    844
    Thanks Received
    992
    Default
    Quote Originally Posted by j_garcia View Post
    One alternative would be going with the 3312 as it can still handle 3D, and add an external amp if you want more power.
  6. #6
    j_garcia's Avatar
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,290
    Thanks Given
    1,664
    Thanks Received
    3,807
    Default
    Best time to buy last year's model is when the new one comes out I saw a couple of threads saying the 3312 was going for around $500 when on sale? That's a good deal. I bought my dad a refurb 1912 and its a pretty good receiver.
  7. #7
    Steve81's Avatar
    Join Date
    Aug 2012
    Location
    Posts
    2,073
    Thanks Given
    844
    Thanks Received
    992
    Default
    I can't claim to follow the pricing that closely, but I did see the 3312 refurbed at A4L for $599, which is what the UMC-200 is currently going for.
  8. #8
    Join Date
    Mar 2013
    Posts
    3
    Thanks Given
    0
    Thanks Received
    0
    Default
    Thanks for the good advice!
  9. #9
    AcuDefTechGuy's Avatar
    AcuDefTechGuy is online now Audioholic Overlord AcuDefTechGuy should be listened to
    Join Date
    Jul 2007
    Location
    Krypton
    Posts
    13,589
    Thanks Given
    3,377
    Thanks Received
    3,031
    Default
    Most people are incapable of differentiating between DACs, with all things being (AVR vs AVR vs Pre-pro vs DAC vs Player).
    REVEL SALON2 . B&W 802D2 . KEF 201/2 (6) . LINKWITZ ORION3 . TAD 2201 . DYNAUDIO X32 . FOCAL 826V . ATC SCM7 . PHILHARMONIC 3 . FUNK 18.0 (2) . RBH SX-1010N (2) . VELODYNE SC600 (4) . PIONEER MM301 (8) . DENON AVP-A1HD/AVR-5308/AVR-3312/DVD-3800BD . ATI 3005/3002/2004/6012 . BENQ W6000 . ADCOM GFS-600 . APPLE TV . KIMBER KABLE 8PR
    My System Photo . My System Video
  10. #10
    cpp's Avatar
    cpp
    cpp is offline Audioholic General cpp should be listened to
    Join Date
    Dec 2005
    Location
    Lexington SC/Orlando Fla
    Posts
    1,066
    Thanks Given
    250
    Thanks Received
    322
    Default
    Quote Originally Posted by acudeftechguy View Post
    most people are incapable of differentiating between dacs, with all things being (avr vs avr vs pre-pro vs dac vs player).
    r...i..g...h....t
    Bring your old self down my way, set back and listen while we watch the boaters on the lake as we demo and compare DAC vs player
    #1 Vincent Sp-331mkII amp, ATI 2002, Quicksilver's Mid Mono amplifier(2), Wyred for Sound STP-SE, (pre-amp), Rogue 99 Pre-amp, Jolida JD-9A, Micro Seiki bl-91, Kef 104.2, Usher be718, Rega Apollo, Sony xA5400ES, #2 Win7, Synology DS413 NAS w/Seagate 4 -2TB HHD, JRiver17, EE DAC Plus, Mytek DSD DAC, Genelec 8030A,Kef140
    : #3 HT; Denon 4311Ci,GE Triton 2's, Sat50C, Sat3's, Rythmik D15se, OPPO-95,
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
