Not one measurement to independently verify manufacturer specs?![]()
admin should be listened to
You want high end two-channel. Emotiva has got your back with their new XSP-1 Two-Channel Preamp. Check out our Video coverage of this product.
Discuss "Emotiva XSP-1 Preamp Video Review" here. Read the article.
bootman is a forum member in good standing
KEW should be listened to
Has anyone heard what the order of the crossover is?
KEW (02-13-2013)
palmharbor is quite helpful
I have the model UMC-1 as it has analog video inputs for my s-vhs and superbeta units
as this unit does not have these "legacy" inputs.
I like mine, the only limitation is that there is a five second delay in the video because
of the copy guard in the HDMI system. This happens when you change inputs and
sometimes when you go from the DVR program to live tv but you learn to live with it.
Tech support on the phone is terrific and these products, especially set up tend to
be complicated and the manual is not well written and does not include important
information but tech support is more than U could ask for.
I recommend this company and their products. I also have the five channel power
amp and it drives my fussy Martin Logans without a problem
CTRL + Q to Enable/Disable GoPhoto.it
You should post that in a umc thread.
This is about their analog preamp and doesn't really apply.
apples and oranges.
TheWarrior has a small fan club
The video reviews keep getting better and better!
gene (02-17-2013)
sharkman is looking for a job at AH
Wow, another Emotiva review. They sure are popping out the products.
