AcuDefTechGuy (08-21-2012),ahblaza (08-21-2012)
I copied down my level settings before installing the amp for the LR mains. Then I adjusted the amps attenuators to get the center and surround as close as possible (+/- 0.5db) to the previous values. Basically I level matched the new amp to the AVR amp and that's it so it really doesn't matter where you start off but 80% or so should put you close.
Steve
j_nordi
SPEAKERS ARX A5 (LCR) X 3
SIDES: ARX1b X 4
HTD: Level Three Monitors
Pioneer BS41's
SUBS: PSA XS30 X 2
RECEIVER: Onkyo 809, 709, TX-SR702
AMPS: EMO XPA-3 & 200, ATI AT602, ONK. M-282
DISPLAY: Panny 65GT50
PLAYERS: Panny BD-85, PS3 Slim
JUST ADDED: Panny DMP-BDT500
Rotel RCD-955AX
TURNTABLE: Sota Sapphire 111 with
Jelco SA-250ST and AT440MLa cart
MUSIC HALL Pa 1.2 Phono Pre
RNG200N DVR
TRIPP-Lite HT10DBS
WHOLE HOUSE SS
BJC All Cables
CECIL WATTS: DUST BUG
j_nordi
SIDES: ARX1b X 4
Pioneer BS41's
SUBS: PSA XS30 X 2
Rotel RCD-955AX
RNG200N DVR
TRIPP-Lite HT10DBS
WHOLE HOUSE SS
BJC All Cables
Last night I hooked the Crown XLS2500 to my dual RBH subs. Set the Crown gain to 100%. To achieve the usual 75dB SPL, I have to reduce the Denon speaker channel level of the sub to -12.0.
So I bet setting the Crown gain to 100% is equivalent to an amp gain of at least 28dB. Maybe 34dB.![]()
REVEL SALON2 . B&W 802D2 . KEF 201/2 (6) . LINKWITZ ORION3 . TAD 2201 . DYNAUDIO X32 . FOCAL 826V . ATC SCM7 . PHILHARMONIC 3 . FUNK 18.0 (2) . RBH SX-1010N (2) . VELODYNE SC600 (4) . PIONEER MM301 (8) . DENON AVP-A1HD/AVR-5308/AVR-3312/DVD-3800BD . ATI 3005/3002/2004/6012 . BENQ W6000 . ADCOM GFS-600 . APPLE TV . KIMBER KABLE 8PR
My System Photo . My System Video
ahblaza (08-22-2012)
DS-21 is off the scale
Irvrobinson (08-23-2012)
Irvrobinson should be listened to
http://www.avsforum.com/t/855865/measuring-amplifiers
edit: the K and XS series is ok ... the Xti might not be that good.
-0-
to the guys that have this amp, is there a voltage switch at the back? 110 to 240?
