I believe this is what you looking for:
For only $33.60 each when QTY 50+ purchased - Component (YpbPr) to VGA Converter | Analog Video Converters
StratCountry is a forum member in good standing
Is it possible to connect a y cb cr connection from my Marantz SR18 receiver monitor out output jacks to a computer lcd monitor that has a vga female connection?
I have already tried a y cb cr cable end to vga cable end from my receiver to a lcd monitor, monitor reads: no signal.
Would I need a signal converter, I'm uncertain whether the monitor accepts digital or analog signal. I understand my receiver's y cb cr monitor out jacks are digital.
Could you advise me what I need, my display lights no longer work on my Marantz, so I need to connect the receiver to lcd monitor as a OSD.
Thank you,
Jerome
TV: TC-P55ST30 , AVR: TX-SR805. The Speaker Company 2x TST2, TC2, 2x TSB , Premier Acoustic PA-120 Sub, Netgear NeoTV 550, Harmony 880 URC RFS200, PC->Toslink-> Audioengine D1->JBL LSR2325P
When you're arguing with an idiot, make sure the person you are speaking to isn't doing the same thing.
StratCountry (08-10-2012)
Thank you for taking the time looking up on what I may need. I checked this converter out, question: Isn't y pb pr an analog signal cable which this concerter is? My receiver has y cb cr outputs, as I recall is digital signal.
Thank you,
Jerome
