Results 1 to 4 of 4
Thread: Topping TP20 and TP60 Comparison
  1. #1
    newtoaudio90 is offline Enthusiast newtoaudio90 is a forum member in good standing
    Join Date
    Jul 2012
    Posts
    24
    Thanks Given
    6
    Thanks Received
    0
    Default Topping TP20 and TP60 Comparison
    Hey guys I have yet another question about the t-amps.
    I see various reviews comparing TP20 to TP22 etc
    However was wondering if anyone could comment ( or link me ) to a direct comparison of the TP60 and TP20?
    On that note a question: TP20 specs:
    Output power: 23 watts x 2 (4 ohms, 10% THD) • Tripath TA2020 T-Amp IC • Signal-to-noise ratio (SNR): 98 dB • Dynamic range: 98 dB • IHF-IM Distortion: 0.1% @ 1 watt (4 ohms) • THD Distortion: 0.03% @ 9 watts (4 ohms), 0.1% @ 10 watts (4 ohms), 0.1% @ 6 watts (8 ohms), 10% @ 23 watts (4 ohms), 10% @ 13 watts (8 ohms) • Power efficiency: 81% @ 20 watts (4 ohms), 88% @ 12 watts, (8 ohms) • Input sensitivity: 200 mV • RCA audio input jacks • Power indicator (Blue LED) • Dimensions: 3.54" W x 1.97" H x 6.38" D (90 x 50 x 162 mm).
    TP60 specs
    Power output: 2 x 80W (into 4Ω @ 10% THD), 2 x 48W (into 4Ω @ 0.1% THD), 2 x 50W (into 8Ω @ 10% THD), 2 x 27W (into 8Ω @ 0.1% THD) • Dynamic range: 102 dB • Signal-to-noise ratio: 98 dB • Power efficiency: 81% @ 80W into 4Ω, 88% @ 50W into 8Ω • Input sensitivity: 200 mV • Weight: 11 lbs. • Dimensions: 11.375" (288.9 mm) L x 6.625" (168.28 mm) W x 3.375" (85.73 mm) H.
    Why in the TP20 is more power (23watt) able to go into 4 ohms and int he TP60 the greater amount of power goes into 8ohms (8watts).
    I thought power would have to increase into lower impedence in both? Or visa versa... I just dont get why its following a different pattern (at the same THD)
  2. #2
    markw's Avatar
    markw is online now Audioholic Spartan markw should be listened to
    Join Date
    Nov 2003
    Location
    New Joisey
    Posts
    7,493
    Thanks Given
    847
    Thanks Received
    1,913
    Default
    These are questions you need to ask the designers of the amp, but I'm starting to think you already knew that.
    "Knowledge is knowing that a tomato is a fruit; wisdom is knowing not to put it in a fruit salad" - Anonymous
    Some of my systems: http://cgi.audioasylum.com/systems/1606.html
  3. #3
    Adam's Avatar
    Adam is online now Audioholic Jedi Adam should be listened to
    Join Date
    Jul 2006
    Location
    Tucson, Arizona
    Posts
    26,516
    Thanks Given
    7,573
    Thanks Received
    9,125
    Default
    Quote Originally Posted by newtoaudio90 View Post
    I don't see that. Both set of specs show a higher power rating (at a given THD) at 4 ohms.
    Mains and Surrounds: NHT 1.5s, Center: NHT AudioCenter-1, Subs: SVS PC13-Ultra, SB13-Ultra, Receiver: Pioneer Elite VSX-23, Amps: Emotiva RPA-1, POS-1, Display: Panasonic TC-P50G10
  4. #4
    Join Date
    Jul 2012
    Posts
    24
    Thanks Given
    6
    Thanks Received
    0
    Default
    I dont know what I was looking at yesterday, but today with fresh eyes I agree. Sorry
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
