Results 1 to 6 of 6
Thread: Video output problem on Yamaha RX-V663
  1. #1
    angelo newbie is offline Audiophyte angelo newbie is a forum member in good standing
    Join Date
    Apr 2008
    Posts
    8
    Thanks Given
    12
    Thanks Received
    0
    Default Video output problem on Yamaha RX-V663
    Trying to assess a problem with video output to a Toshiba DVD player that has never been a problem in the past. The Yamaha is about 4 yrs. old and gets continual use (whenever the TV is turned on). Two days ago we tried to play a movie in a Toshiba DVD player and got sound, but no picture. This has never happened before and we had just watched a movie the previous night without incident. I have tried to troubleshoot as follows: Changed out the CD several times.. Changed out the DVD player to a brand new unit.... Changed out the component cables with new cables... Switched the component cables to different video outputs. Still no video through the DVD player, although the TV/Cable is working fine. Is the receiver video output fried?? Or am I missing something? Thanks for any advice.
    Angelo
  2. #2
    Grador is online now Audioholic General Grador is looking for a job at AH
    Join Date
    Feb 2012
    Location
    SoCal
    Posts
    1,262
    Thanks Given
    183
    Thanks Received
    324
    Default
    Have you tried plugging the video from the DVD player directly into the TV? It could also be the DVD player that died.
    HT: Samsung LN32B460 32" LCD (greyscale calibrated) | AVR: Yamaha RX-V765 | L/R: Emp E55Ti | C: Paradigm Center 1 | Rears: Sony Junk | SW: Klipsch RW-10d miniDSP | Sources: Acer Revo Ion running XBMC with mySQL library server and 4 TB HDD, PS3, Technics SL-Q2 TT | 2x Aura Pro Bass Shakers
    Bookshelf: Yamaha RX-V992 | Paradigm Mini Monitors
    Shelved for now: Paradigm 11 SE Deluxe
  3. #3
    TLS Guy's Avatar
    TLS Guy is offline Audioholic Warlord TLS Guy should be listened to
    Join Date
    Oct 2007
    Location
    Benedict MN
    Posts
    9,876
    Thanks Given
    865
    Thanks Received
    4,017
    Default
    Quote Originally Posted by angelo newbie View Post
    Angelo
    I bet this is a resolution miss match.
    Your DVD player is 480i, so the receiver has to up convert it to the resolution of your TV.
    Make sure the up resolution in your receiver is turned on and the the resolution from the output of your receiver matches that of the TV.
    I had a similar issue last week, in that I had no picture from my BD player, but sound.
    It turned out that the BD player had changed its output resolution all by itself.
    Since you are having this problem with two different DVD players, I would bet this is the issue.
    Marantz DV 9600 Oppo BD-83 Marantz AV 8003 Quad current dumping amps X 7 Direct TV HD 20 HD DVR Carter audio workstation RME Fireface 800 Fujitsu 50XHA40 Front left and right Carter dual transmission line studio monitors MK II. Center Carter coaxial transmission line center speaker Rear Carter NFM-1s Center backs Carter dual transmission line studio monitors MK I. My system: - http://mdcarter.smugmug.com/gallery/...27077317_Pufg7
  4. #4
    Clint DeBoer's Avatar
    Clint DeBoer is offline Administrator Clint DeBoer should be listened to
    Join Date
    Jul 2002
    Location
    Lakeland, Florida, United States
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default
    Do you really mean "through" the DVD player? Are you using an old player that has an integrated tuner or which passes video through it? I'm guessing not, but just wanted to clarify.
    From what you said it sounds like you completely removed both the player and cables from the equation, leaving the receiver - which can be verified if you plug the video source (DVD) directly into the TV and it works.
    Clint DeBoer
    Editor in Chief
    Audioholics
  5. #5
    Join Date
    Apr 2008
    Posts
    8
    Thanks Given
    12
    Thanks Received
    0
    Default
    Thanks to all who took the time to provide their expertise provided with my video problem. I resolved the issue by hooking the DVD player directly to the TV as several of you suggested. This took the receiver out of the video loop and the problem went away. Takes an extra step to switch over but we are now back on line. Thanks again!
    Angelo
  6. #6
    TLS Guy's Avatar
    Join Date
    Oct 2007
    Location
    Benedict MN
    Posts
    9,876
    Thanks Given
    865
    Thanks Received
    4,017
    Default
    Angelo
    I would still go to the video set up menu of the receiver and check the output resolution and change as indicated. I have a strong feeling that is your problem.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
