Results 1 to 7 of 7
Thread: Denon AVR-889 new HDMI Handshake issue?
  1. #1
    nm2285 is offline Senior Audioholic nm2285 is a forum member in good standing
    Join Date
    Mar 2004
    Posts
    658
    Thanks Given
    0
    Thanks Received
    1
    Default Denon AVR-889 new HDMI Handshake issue?
    Hey all. I have a Directv DVR hooked up to my Denon receiver and then to my Panasonic TV. The system had worked perfectly probably for about 2 years. Just about a week ago, the system started having issues when I'd change channels on Directv. I would lose all audio/video signal anywhere from 30 sec to 10-15 min. Turning everything off and on again would sometimes fix the issue. It seems to me that it's a HDMI handshake problem, but why would it just begin now with no changes made to the system? Any way to fix it?
    Thanks for the help!
  2. #2
    slipperybidness's Avatar
    slipperybidness is online now Audioholic General slipperybidness should be listened to
    Join Date
    Jul 2011
    Posts
    1,267
    Thanks Given
    29
    Thanks Received
    293
    Default
    Quote Originally Posted by nm2285 View Post
    Check all your cables. Any chance you, a child, a pet has been poking around the back panels lately. Check all HDMI cables and reseat them in the socket. You may want to try swapping around some cables to see if the problem goes away or changes.
    You may have a more serious problem, but start with the easy stuff first. I had a similar issue a while back after making some changes to my setup. A cable that worked perfectly from the cable box to the stereo did not work very well at all when used from stereo to TV.
  3. #3
    Grador is offline Audioholic General Grador is looking for a job at AH
    Join Date
    Feb 2012
    Location
    SoCal
    Posts
    1,266
    Thanks Given
    185
    Thanks Received
    328
    Default
    It is also possible, yet somewhat unlikely that your cable box had some form of update which broke things.
    HT: Samsung LN32B460 32" LCD (greyscale calibrated) | AVR: Yamaha RX-V765 | L/R: Emp E55Ti | C: Paradigm Center 1 | Rears: Sony Junk | SW: Klipsch RW-10d miniDSP | Sources: Acer Revo Ion running XBMC with mySQL library server and 4 TB HDD, PS3, Technics SL-Q2 TT | 2x Aura Pro Bass Shakers
    Bookshelf: Yamaha RX-V992 | Paradigm Mini Monitors
    Shelved for now: Paradigm 11 SE Deluxe
  4. #4
    Join Date
    Mar 2004
    Posts
    658
    Thanks Given
    0
    Thanks Received
    1
    Default
    i'm thinking it's the update issue. i've tried different inputs and cables. i'll have to contact them to ask about recent updates.
  5. #5
    Tomorrow's Avatar
    Tomorrow is online now Audioholic Ninja Tomorrow should be listened to
    Join Date
    Mar 2005
    Posts
    4,216
    Thanks Given
    1,098
    Thanks Received
    961
    Default
    It's a DirecTV firmware upgrade bug. I believe it does have HDMI handshake issues. Of course the tech support people blame it on the receiver (mine did the same thing...on a Panasonic tv and a Yamaha Rx). It's not the cabling.
    My fix was to change the DTV DVR to output a 720P resolution instead of 1080i. Now it works just fine.
    Good luck. Hopefully this little workaround will do it for you, too.
    There are three kinds of people...those who can count and those who can't.
  6. #6
    M Code's Avatar
    M Code is online now Full Audioholic M Code should be listened to
    Join Date
    Oct 2009
    Location
    Lake Piru, CA
    Posts
    359
    Thanks Given
    1
    Thanks Received
    108
    Default
    Continuous, known issues..
    Direct TV boxes are not HDMI certified..
    Without this certification there is no confidence that the Direct TV box has been tested for interoperabilty with other HDMI products including AVRs..
    Just my $0.02..
  7. #7
    dqkelley is offline Audiophyte dqkelley is a forum member in good standing
    Join Date
    Jun 2012
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default Thanks for the solved handshake
    The same problem happened to me ... thanks, Tomorrow, for your solution. Directv is such a pain!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
