Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Onkyo Pure Audio with Sub?
  1. #21
    LAB3's Avatar
    LAB3 is offline Senior Audioholic LAB3 should be listened to
    Join Date
    Dec 2010
    Location
    DFW, Texas
    Posts
    523
    Thanks Given
    109
    Thanks Received
    56
    Default
    Quote Originally Posted by Jay_C View Post
    No. I used pure audio in another room with the same equitment and it is fantastic.
    Problem is this my room has limited space and speaker position isnt great at all which is preventing me feeling the bass.
    sure it not PURE but i want to get as close to pure audio with minimal processing as possable until i can fix room layout. which i have gotten.
    Same here, I like Pure when I play back from my Revox R2R..... my AVR also has a "Straight Analog" mode (no processor but subs work) and I wired my Yamaha CD Changer RCA(analog side of AVR no HDMI) to record to tapes.. DAC is Burr Brown
    in AVR and I have second DAC inline (RCA) from AVR to R2R for recording. I have tried every way to listen to music ... at least Analog. Now with a CD I just use the Bluray player and go Stereo thru HDMI and tweak the Eq. in YPAO (Yamaha Audessey)if the mids get a might "bright" front speakers are rather large and 7 feet apart and sofa 7 feet back with 2 mid level subs turned down some. To each his own as I had tube seperates many years ago before HD Audio and Bluray, now I am hooked on all of them and can't afford anymore then I have now in this small room.Some AVR do make old Klipsch sound good in a little room
    Toshiba 55" LCD/LED
    Yamaha RX-V1900 HD 7.1 AVR
    Yamaha CDC-867
    Samsung BD-P1600 Blu-ray
    Klipsch 1979 Cornwall Crites Mod's
    Klipsch RC-62 Center
    Klipsch RS3-II Rears
    Klipsch Synergy Sub 12 X2
    Revox A-77 Mk IV Dolby R2R
    Akai GX-4000D
    Nakamichi BX-100
    Pioneer PL-518X TT
    Pickering XUV D4500Q
    Bedroom
    Yamaha RX-V2400 A/V Receiver
    Klipsch Heresy II
    Klipsch KSB 1.1 X 3
    Toshiba 46" LED
    Sony BDP-S300 Blu-ray
    Akai 4000 DS MK II
    Kenwood KX-97CW
  2. #22
    Sbezooyen is offline Audiophyte Sbezooyen is a forum member in good standing
    Join Date
    Apr 2013
    Location
    Alberta
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default
    I have found a way around this problem I hooked my sub left right inputs off the front channel pre outs on the onkyo 809 for 2.1 channel pure audio without running high level inputs dosent work great for movies tho so all I have to do is leave a LFE cord behind the sub and swap it out for movies
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
