Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Marantz NR1602 or Denon AVR 1912
  1. #11
    j_garcia's Avatar
    j_garcia is offline Seriously, I have no life. j_garcia should be listened to
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,285
    Thanks Given
    1,664
    Thanks Received
    3,805
    Default
    Same 90W as the 1912, so unless it offers a specific feature you need, it won't be an upgrade.
    HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
    System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
    Are you sure which side of the glass you are on?
  2. #12
    alphaiii is offline Audioholic Chief alphaiii should be listened to
    Join Date
    Nov 2008
    Location
    Maryland
    Posts
    798
    Thanks Given
    20
    Thanks Received
    110
    Default
    Quote Originally Posted by j_garcia View Post
    I don't think the slimline digital amp models are going to be as good as the traditional class AB models.
    The Marantz slimline AVR's still use AB amplification and discrete channels... They don't use digital amps like the Panasonic (among a few others) AVR's did.
    Living Room: Samsung 46A630, PS3, Panasonic BD85, Denon 991, APC H10, NHT Classic 3/2C, Emotiva Ultra-12
    Bedroom: LG 42LD550, Panasonic BDT210, Marantz NR1402, Acoustic Energy Aego-T, Pioneer SW-8
    PC: Hot Audio DAC Destroyer, Audioengine N22, Paul Carmody's Overnight Sensations
  3. #13
    Join Date
    Nov 2008
    Location
    Maryland
    Posts
    798
    Thanks Given
    20
    Thanks Received
    110
    Default
    The 2112 adds Audyssey MultiEQ XT.... the 1912 only has MultiEQ.
    For those on a budget that don't need networking or video upconversion... the 1712 has XT and the same exact 90W per channel as the 1912/2112.
  4. #14
    j_garcia's Avatar
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,285
    Thanks Given
    1,664
    Thanks Received
    3,805
    Default
    Quote Originally Posted by alphaiii View Post
    I could have sworn they were digital, but I guess I was mixing them up.
  5. #15
    Join Date
    Nov 2008
    Location
    Maryland
    Posts
    798
    Thanks Given
    20
    Thanks Received
    110
    Default
    Yeah, you'd think so given the small size. So far, I have yet to hear that it doesn't deliver the rated 50W per channel. So I applaud Marantz for keeping discrete class AB amplification in the smaller form factor, and somehow avoiding any heat issues that might be a problem with a small chassis (at least, I've never had heat issues with the NR1402)
    I can say, the NR1402 is pretty stout at 19lbs for it's "slim" size. I have a Panasonic XR55 a few years ago, and if I remember, it was only about 11lbs.
  6. #16
    GranteedEV's Avatar
    GranteedEV is offline Audioholic Ninja GranteedEV should be listened to
    Join Date
    Jul 2009
    Location
    Calgary, Canada
    Posts
    4,484
    Thanks Given
    1,967
    Thanks Received
    2,034
    Default
    Get a marantz sr5005 from accessories4less. Unlike the 1912 it has preamp outs.
    System: Marantz SR6003
    ---> Crown XLS 2000 ---> Philharmonic Model 2
    ---> Tapco Juice J2500 --> DIY Maelstrom X
    Victory goes... TO THOSE WITH COURAGE!!!
  7. #17
    dwh
    dwh is offline Banned dwh is off the scale
    Join Date
    Apr 2012
    Location
    North East Arkansas
    Posts
    19
    Thanks Given
    3
    Thanks Received
    0
    Default
    I was looking at the SR5005, but read a lot of mixed reviews about the refurbed 5005s. Lots of issues showing up after 6+ hours of constant use. Sounds like they aren't "burning them in" overnight before testing.
  8. #18
    Join Date
    Nov 2008
    Location
    Maryland
    Posts
    798
    Thanks Given
    20
    Thanks Received
    110
    Default
    Not sure if it matters to you... but just FYI...
    The SR5005, like the NR1601, has the best text GUI that does not overlay.
    The pre-outs are nice to have though.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
