I paired up my STR-DG1000 with a pair of Thiel CS.5 floorstanding speakers. The two seem to work well together despite the notoriety of Thiel and their reactive loads the receiver doesn't get hot at all running them and there's no noticeable stress.
The receiver does have preouts for all channels. Would it be advised to get a power amplifier, would it have a real world improvement?
Seth=L (02-29-2012)
Sensitivity is is 89dB, minimum impedance is 4 ohms.
http://www.stereophile.com/content/t...r-measurements
I say no need for external amp.
REVEL SALON2 . B&W 802D2 . KEF 201/2 (6) . LINKWITZ ORION3 . TAD 2201 . DYNAUDIO X32 . FOCAL 826V . ATC SCM7 . PHILHARMONIC 3 . FUNK 18.0 (2) . RBH SX-1010N (2) . VELODYNE SC600 (4) . PIONEER MM301 (8) . DENON AVP-A1HD/AVR-5308/AVR-3312/DVD-3800BD . ATI 3005/3002/2004/6012 . BENQ W6000 . ADCOM GFS-600 . APPLE TV . KIMBER KABLE 8PR
My System Photo . My System Video
TV: TC-P55ST30 , AVR: TX-SR805. The Speaker Company 2x TST2, TC2, 2x TSB , Premier Acoustic PA-120 Sub, Netgear NeoTV 550, Harmony 880 URC RFS200, PC->Toslink-> Audioengine D1->JBL LSR2325P
When you're arguing with an idiot, make sure the person you are speaking to isn't doing the same thing.
I the room isn't overly large. They definitely need a large area to perform well. Tried them out in a smaller room and they did not sound good at all.
According to stereophile's measurements they say the speaker spends most of it's time around 4 Ohms above 200Hz.
I've been slowly getting to know what these speakers can do and I can honestly say I've never had anything that can present a soundstage as defined as this little Thiels. One of the woofers has a slight wrinkle in it though. Despite the wrinkle they don't seem to be affected much by it.
Below 200 Hz the Thiels present an impedance load at or below 4 ohms. I don't know how powerful your Sony receiver is, and more importantly, how stable it is driving low impedance loads.
Its rated by Sony at 120 wpc at 8 ohms (measured at 1kHz at 0.7% THD), and Crutchfield says 110 wpc at 8 ohms (measured 20-20,000 Hz at 0.09% THD). I assume this is while 2 channels are driven. But these ratings say nothing about 4 ohms or lower.
It is possible that an amp capable of delivering steady power at low impedance loads can produce better sounding (cleaner and less uncontrolled) and possibly louder bass from your Thiels. I looked briefly on Audiogon and found two inexpensive used Hafler amps.
Hafler DH-200 rated at 100 wpc
Hafler SE240 rated at 120 wpc
Other more powerful amps may have a similar effect, but I know these Haflers are good at driving low impedance speakers.
HT System
Rcvr B&K AVR 507 Amp B&K EX4420 (main speakers) Main speakers Salk SongTower QWT Center Salk SongCenter Surrounds NHT SuperZero Subwoofer DIY PE RS 12" HF 2 ft³ cabinet with HPSA 500 amp BR player Panasonic DMP-BDT500 TV Panasonic TC-L37G1 Phonograph ARxa, Sumiko Oyster cartridge & Audio Technica PEQ3 preamp
SongTower Listening Impressions - Photos
2-channel system
CD Player Sony CDP-591 Pre-amp Marantz 2230 stereo receiver Amplifier B&K ST-140 Speakers DIY 2-way CAOW1
I feel the Sony does an excellent job. I chose this receiver because of it's raw power capability. It has a large extruded heatsink and produces very low heat even when I'm using surround sound (all 5 of my speakers are rated at 4 ohms I believe. For the money I can't think of a more powerful receiver with the features I need.
Sony has been doing good lately, with the 10XX series. The measurements
on the 1020 are good - and looks good at 4 ohms
Sony STR-DN1020 A/V Receiver HT Labs Measures | Home Theater
Who and Where - is the Way, the Truth and the Life?
Speakers > Boston VS 260, Snell K7, Boston E60,
Pioneer BS22, Cambridge S30 (modified)
Receiver > Denon 791, Pioneer Elite VSX30
