Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Anthem Statement M1 Class D Monobloc Preview
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Anthem Statement M1 Class D Monobloc Preview
    While we're not sure how well the Statement M1 will sell, it certainly looks good on paper. Given the 2000 watts of power with a highly efficient Class D design, it certainly will turn heads. Anthem set an impressive list of design goals for themselves and they believe they've achieved them. If so, you may be looking at an amp that will require much less space, can be stacked, outputs more power with less heat, is stable into any load, and sounds as good as any analogue amp. Is that worth $3500 per channel? We're guessing to many high-end users, it is.
    Discuss "Anthem Statement M1 Class D Monobloc Preview" here. Read the article.
  2. #2
    beyond 1000 is offline Enthusiast beyond 1000 is a forum member in good standing
    Join Date
    Mar 2008
    Posts
    11
    Thanks Given
    1
    Thanks Received
    1
    Default
    I think $3500 is a bit much for a 20lb amp even if it had 10k wpc.
    There are many ways to spend your money in hi end audio better than this.
  3. #3
    dsmith901 is offline Audiophyte dsmith901 is a forum member in good standing
    Join Date
    Feb 2006
    Posts
    4
    Thanks Given
    0
    Thanks Received
    0
    Default Overpriced for sure
    IMO, for a $3,500 mono amp the specs are nothing to brag about. Measuring at 20-20K Hz is a barely acceptable FR range and a 0.1 THD target is likewise barely acceptable for a high end product. Lots of amps will put out impressive power at 0.1 THD; the trick is to do it at 0.01 or (preferably) less, RMS on a continuous basis. Of course the real test is listening, which given Anthem's highly restricted marketing policies I don't expect to experience.
  4. #4
    AcuDefTechGuy's Avatar
    AcuDefTechGuy is online now Audioholic Overlord AcuDefTechGuy should be listened to
    Join Date
    Jul 2007
    Location
    Krypton
    Posts
    13,590
    Thanks Given
    3,377
    Thanks Received
    3,032
    Default
    Looks like an Outlaw M2200 w/ more power to me.
    REVEL SALON2 . B&W 802D2 . KEF 201/2 (6) . LINKWITZ ORION3 . TAD 2201 . DYNAUDIO X32 . FOCAL 826V . ATC SCM7 . PHILHARMONIC 3 . FUNK 18.0 (2) . RBH SX-1010N (2) . VELODYNE SC600 (4) . PIONEER MM301 (8) . DENON AVP-A1HD/AVR-5308/AVR-3312/DVD-3800BD . ATI 3005/3002/2004/6012 . BENQ W6000 . ADCOM GFS-600 . APPLE TV . KIMBER KABLE 8PR
    My System Photo . My System Video
  5. #5
    cpp's Avatar
    cpp
    cpp is offline Audioholic General cpp should be listened to
    Join Date
    Dec 2005
    Location
    Lexington SC/Orlando Fla
    Posts
    1,066
    Thanks Given
    250
    Thanks Received
    322
    Default
    And the Outlaw 2200 amp is only $350.00 each.
    Power Output: 200 watts @ 8 ohms, 20 Hz - 20 kHz, <0.05% THD; 300 watts @ 4 ohms, 20 Hz - 20 kHz, <0.05%
    THD Signal to Noise: 112 dB "A" weighted
    Input Impedance: >10K Ohms
    Gain: +27dB (1.7V sensitivity) for full output
    Input Connectors: RCA Jack, XLR Jack
    Output Connectors: Five-Way Binding Posts
    Power Consumption: 600 watts maximum/<3 watts standby
    Trigger Input: 6-35 V DC 4mA
    Weight: 18 pounds
    Dimensions (H/W/D):1.75" x 17" with feet x 11.5"
    #1 Vincent Sp-331mkII amp, ATI 2002, Quicksilver's Mid Mono amplifier(2), Wyred for Sound STP-SE, (pre-amp), Rogue 99 Pre-amp, Jolida JD-9A, Micro Seiki bl-91, Kef 104.2, Usher be718, Rega Apollo, Sony xA5400ES, #2 Win7, Synology DS413 NAS w/Seagate 4 -2TB HHD, JRiver17, EE DAC Plus, Mytek DSD DAC, Genelec 8030A,Kef140
    : #3 HT; Denon 4311Ci,GE Triton 2's, Sat50C, Sat3's, Rythmik D15se, OPPO-95,
  6. #6
    Jeepers is offline Audioholic Jeepers is quite helpful
    Join Date
    Mar 2007
    Posts
    193
    Thanks Given
    37
    Thanks Received
    24
    Default
    This was the preview, for when is the review ?
  7. #7
    haraldo's Avatar
    haraldo is online now Audioholic Ninja haraldo should be listened to
    Join Date
    Feb 2008
    Location
    wild wild west, Norway, home of Vikings
    Posts
    4,834
    Thanks Given
    1,719
    Thanks Received
    842
    Default
    Quote Originally Posted by AcuDefTechGuy View Post
    Yeah, looks quite similar except for the fact that they are totally different.....
    The Outlaw is 200W @ 8 ohms, and it's class G.
    But the outlaw is interesting too....
    In general: To say that the Anthem is just overpriced without even digging deeply into what's inside is a bit too quick if you ask me, if it's close to what they state that it's on top of the class of Class-D amps then it's not so pricey....
    If we were only thinking of making everything as dirt cheap as possible...... why don't we all drive around in cars like this?
    It does the same as a Camaro, just not as fast..... same as to compare the Outlaw anf the Anthem if you ask me
    Although it will be interesting to see the new amps based on the Hypex ncore module, they developed a new module with an output impedance so low that it's almost impossible to measure....
    something like an output impedance that equals 3 feet of 4 gauge wire
    well although it's a bit unfair still as they're not even close to being in the same leahe as the Anthem when we talk about power...
    NC400
    http://www.hypex.nl/docs/papers/ncore%20wp.pdf
    They also make completed amps, not only modules for DIY'ers....
    It's claimed the ncore is a different animal than the UcD class-d modules... would really like to audition one of these guys....
    There is only NOW
  8. #8
    NewYorkBlack is offline Banned NewYorkBlack is a forum member in good standing
    Join Date
    Feb 2012
    Posts
    3
    Thanks Given
    0
    Thanks Received
    0
    Default
    I personally don't think the price of this monoblock is not too bad.. Heck PassLabs monoblock cost $13,000 and it gives about the same power output.
    One should ask if this kinda power is really needed for home theater use? Subs, yes but towers, I pretty much doubt it. So far, Emotiva and Outlaw seems to be the best bang for the buck.
  9. #9
    DS-21 is offline Full Audioholic DS-21 is off the scale
    Join Date
    Aug 2011
    Posts
    486
    Thanks Given
    12
    Thanks Received
    174
    Default
    Quote Originally Posted by beyond 1000 View Post
    Since when is worth of an amplifier correlated to its mass?
    I'd rather have an amplifier that is lighter, quieter, and more energy efficient for the same power.
    It's actually nothing like Outlaw's knockoff of the old NHT A1 monobloc: Class D rather than G, SMPS rather than torroid-based PS, considerably deeper chassis, and roughly 10x more powerful.
    Here's a gut shot:
    Though for most uses I'd guess the only functional difference between them is that the Anthem would be more energy-efficient at typically-demanded power levels. Unless one's rack isn't deep enough to fit the Anthem, in which case it will be an eyesore compared to the Outlaw.
    Perhaps a better way to think of the Anthem amp is as a slightly less powerful but much much better-looking and quieter (because it has no fan) half-height Peavey IPR-3000*. (the IPR-3000 could be 1RU; the only component inside it that wouldn't fit in a 1RU case is 80mm fan. The stock fan is quite loud, but it's just a 12V computer fan, and can be replaced with a quieter one quite easily. One just needs the new fan and either snip some wires or buy an adapter to fit the IPR board's 2-wire plug.)
    In comparison, the Anthem has some other nice features, too, such as a 12V trigger and 2-prong power socket to help avoid ground loops.
    Of course, one also has to consider that the Peavey amp is under $400. $3100 buys a lot of control gizmos and electricians' time to fix grounding problems…
    Now, would I ever buy one of these Anthem amps? No. However, I'd happily pay $3500 for an IPR-3000 with some heat-sinking (to eliminate the fan), a 12V trigger, a glass front panel with two aquamarine-backlit wattmeters... I'd also strongly consider $3500 for an 1RU convection-cooled Class D Anthem (or other brand with similar after-sales support and warranty) amp that was ~150Wx7/8Ω and 250+Wx7/4Ω. The closest thing to that currently available, Harman's similarly-priced Crown Comtech CTS8150 and Lexicon DD-8 twins, is cheaper than that, but has the same power at 8Ω and 4Ω.
    *The IPR-3000 can easily be bridged, but it's kind of kludgey. One needs to use two Speakons to do so. The better-looking and slightly more expensive (and, as of yet, vaporware) Crest Prolite versions of the Peavey IPR should do away with that kludge
  10. The Following User Says Thank You to DS-21 For This Useful Post:
    haraldo (02-22-2012)
  11. #10
    BoredSysAdmin's Avatar
    BoredSysAdmin is online now Audioholic Spartan BoredSysAdmin should be listened to
    Join Date
    Aug 2007
    Location
    NYC
    Posts
    5,607
    Thanks Given
    1,497
    Thanks Received
    1,974
    Default
    you could similar performance out of a pair of bridged Crown XLS 2000 for a 1/4 of the price of Anthem
    TV: TC-P55ST30 , AVR: TX-SR805. The Speaker Company 2x TST2, TC2, 2x TSB , Premier Acoustic PA-120 Sub, Netgear NeoTV 550, Harmony 880 URC RFS200, PC->Toslink-> Audioengine D1->JBL LSR2325P
    When you're arguing with an idiot, make sure the person you are speaking to isn't doing the same thing.
  12. The Following User Says Thank You to BoredSysAdmin For This Useful Post:
    haraldo (02-26-2012)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
