Results 1 to 10 of 10
Thread: Matching reciever with speakers
  1. #1
    d9999 is offline Audioholic Intern d9999 is a forum member in good standing
    Join Date
    Sep 2011
    Posts
    32
    Thanks Given
    29
    Thanks Received
    0
    Default Matching reciever with speakers
    Hey everyone, I am new and looking at getting a new home theater setup. I have a question about matching the receiver and speakers. I read there is a lot about matching the way they sound and some will be too warm etc. So I am thinking of getting possibly Klipsch rf-52 II. What are some receivers that will blend well and what receivers won't? Thanks!
  2. #2
    GranteedEV's Avatar
    GranteedEV is offline Audioholic Ninja GranteedEV should be listened to
    Join Date
    Jul 2009
    Location
    Calgary, Canada
    Posts
    4,486
    Thanks Given
    1,967
    Thanks Received
    2,034
    Default
    Quote Originally Posted by d9999 View Post
    Lucky for you, that's total B.S.
    Just get a marantz SR6004:
    http://www.accessories4less.com/make...eceiver/1.html
    or SR6005:
    http://www.accessories4less.com/inde...SR6005&x=0&y=0
    and be done with it
    Blending would be the last of my worries... the speakers themselves would be the first
    Have you considered any other brands?
    System: Marantz SR6003
    ---> Crown XLS 2000 ---> Philharmonic Model 2
    ---> Tapco Juice J2500 --> DIY Maelstrom X
    Victory goes... TO THOSE WITH COURAGE!!!
  3. #3
    Join Date
    Sep 2011
    Posts
    32
    Thanks Given
    29
    Thanks Received
    0
    Default
    Thanks for the response, what other speakers would you recommend and what do you think of the Klipsch rf-52 II series?
  4. #4
    Join Date
    Sep 2011
    Posts
    32
    Thanks Given
    29
    Thanks Received
    0
    Default
    What speaker brands are you thinking?
  5. #5
    GranteedEV's Avatar
    Join Date
    Jul 2009
    Location
    Calgary, Canada
    Posts
    4,486
    Thanks Given
    1,967
    Thanks Received
    2,034
    Default
    I don't think they're particularily great speakers.
    The RF 52 II will cost about under $800/pr
    A few speakers I'd recommend instead include
    Magnepan MMG - These will sound outstanding, although they won't have the dynamic range or wide sweet spot necessary for a real badass HT setup, they'll really make you rediscover your music either way. You can still watch movies on them, just not as ear-bleedingly loud as the Klipsches. Adding a sub is a great idea.
    EMP e55ti - These will have a balanced response from top to bottom. A sub is necessary to get the deepest octave. They can handle dynamic range pretty well, and have a pretty good sweet spot.
    PSB Image T6 - Probably not as dynamic as the EMPs, but i'd suspect they're a bit better in the lower midrange. Just a guess, as I haven't actually heard them.
    And, at a higher price point:
    JTR Triple 8 - These will be badass. The dynamic range will be endless, and again the voicing will be reasonably neutral.
    And of course, I recommend two quality 12" or larger subwoofers from a company like HSU, Outlaw, Rythmik, Funkywaves, SVS, Epik, or Seaton Sound.
  6. The Following User Says Thank You to GranteedEV For This Useful Post:
    d9999 (09-23-2011)
  7. #6
    BoredSysAdmin's Avatar
    BoredSysAdmin is online now Audioholic Spartan BoredSysAdmin should be listened to
    Join Date
    Aug 2007
    Location
    NYC
    Posts
    5,607
    Thanks Given
    1,497
    Thanks Received
    1,975
    Default
    JTR and PSB T6 are "slightly" above budget
    I'm not huge fan of EMP towers
    My recommendation for $800 2.0 is KEF Q500 ($429/ea)
    http://www.accessories4less.com/inde...y=q500&x=0&y=0
    Or two of these: http://www.amazon.com/Infinity-Primu...6811810&sr=1-1
    and a sub:
    http://emotiva.com/ultra_sub12.shtm
    TV: TC-P55ST30 , AVR: TX-SR805. The Speaker Company 2x TST2, TC2, 2x TSB , Premier Acoustic PA-120 Sub, Netgear NeoTV 550, Harmony 880 URC RFS200, PC->Toslink-> Audioengine D1->JBL LSR2325P
    When you're arguing with an idiot, make sure the person you are speaking to isn't doing the same thing.
  8. The Following User Says Thank You to BoredSysAdmin For This Useful Post:
    d9999 (09-23-2011)
  9. #7
    GranteedEV's Avatar
    Join Date
    Jul 2009
    Location
    Calgary, Canada
    Posts
    4,486
    Thanks Given
    1,967
    Thanks Received
    2,034
    Default
    Quote Originally Posted by BoredSysAdmin View Post
    The T6 I linked to is 849.00/pair
    They can sound a bit thin without EQ if they're away from the wall, but add ~2db boost below 700hz and they're great. Or was your issue something else? Which EMPs did you dislike?
  10. #8
    Knucklehead90's Avatar
    Knucklehead90 is offline Audioholic Knucklehead90 should be listened to
    Join Date
    Jan 2009
    Location
    Sunny Central Washington State
    Posts
    243
    Thanks Given
    10
    Thanks Received
    61
    Default
    I have a nephew with RF-52s with the RC-52 center and the matching surrounds - they play loud as hell with a lightweight Onkyo of a few years vintage. For movies they are very good - for music I think they suck. Too bright by twice or more! Since he's a carpenter he's lost some of his high frequency hearing and it helps him hear dialog and music.
    For strictly music get tower speakers - for movies bookshelf speakers are sufficient as long as you have a good sub. Even with towers a sub is needed for good LFE's in movies. Nothing like shaking the whole damned house!
    For decent bookshelf speakers take a look at the Emotiva offerings. The 6.2s are a fine sounding speaker - and for $199 shipped are the bargain of the late summer/early fall IMO.
    UMC-1 - USP-1 (HT Bypass) - 2x-UPA-1 & A200x3 Amps
    Oppo BDP 80 - ERT-8.3 mains - 6.3 center - ERD-1 surrounds
    Elemental Designs A5-350 Sub
    Infinity Cascade 15 Sub
    2x DIY Sealed 12" Subs
    Harmony 1100 Remote
    BR 2 Channel:
    HK 3390 - A Cheap BR Player
    HK20 Speakers
    Winston Churchill: The best argument against democracy is a 5 minute conversation with the average voter...
  11. The Following User Says Thank You to Knucklehead90 For This Useful Post:
    d9999 (09-23-2011)
  12. #9
    Join Date
    Aug 2007
    Location
    NYC
    Posts
    5,607
    Thanks Given
    1,497
    Thanks Received
    1,975
    Default
    "The T6 I linked to is 849.00/pair "
    My bad, I looked at other number. For $850 T6 is a good option on par with Q500.
    Re Emp e55Ti, I guess I confused with EMP's previous and smaller model.
    I must admit I never heard them, my opinion is based solely on reviews
    On AH reviews Both t55i and T towers measured good, but both have minor issues in frequency sweeps... I guess at this price range its inevitable
  13. #10
    GranteedEV's Avatar
    Join Date
    Jul 2009
    Location
    Calgary, Canada
    Posts
    4,486
    Thanks Given
    1,967
    Thanks Received
    2,034
    Default
    The KEF Q series looks good but I'm a bit concerned about the metal cone breakup I saw in the stereophile measurement. it's only around 12db down in the crossover whereas most designers shoot for ~40db down.
    I'm not sure about the e5Ti. But I like the e55Ti at least, personally. If there's any high Q peak like that measurement showed, I can't hear it. They definitely sound better though if you go into the receiver graphic EQ and boost 500hz / 250hz / 63hz each by ~1.5db, but that might be the fact I've got them 4 feet from the wall!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
