You are correct they do, but not good for recording because your amp volume affects the recorder input. And when not tamed by a volume control, all the EQ background noise makes it 100% to the amp.
jeannot is off the scale
Right.
Well, if you happen to know a technician, a Tape Monitor is really nothing more than a DPDT switch and a pair of RCA jacks inserted in the current circuit - about $10 worth of parts. You can PM me for a diagram targeting your receiver.I suppose all that leaves me is running the source through the EQ and then to the receiver -- but that will only let me hear EQ'ed audio of that particular source, which is not what I was after. I wanted to EQ every source connected -- including low-quality FM and Phono signals. It's disheartening that I am truly SOL here...![]()
Good luck.
Denon 3808CI, HK Citation 5.1 Amp (replaces Denon for front channels), Panasonic 50" Plasma, SONY BDP-37 Player, GoFlex Media Player, Missions for Center, 4x12" home made for subs, Celestion Ditton 25 for fronts, in-wall Good Enough in the back.
For the music: Rio MP3 Receiver, Marantz 2130 tuner, modified Yamaha PC2002 driving Cerwin Vega D-9
PearlcorderS701 is off the scale
Normally, I wouldn't have even responded to this kind of ridiculous, cruel intentioned and spirited comment, but I felt it necessary because you're just being a total ****, and you know it -- let me make something absolutely sparkling clear to you: I'm NOT a troll. I'm NOT dense. I'm not STARVED FOR ATTENTION BECAUSE I ASKED FOR ASSISTANCE ABOUT A GRAPHIC EQ AND HOW IT COULD CONNECT TO MY SETUP. And these questions have NOTHING TO DO WITH "MANNING UP" -- THAT'S JUST ASININE. I'm not WHINING, either -- I'm trying to eliminate EVERY POSSIBILITY REGARDING USING AN EQ IN THIS SYSTEM BY ASKING QUESTIONS ON A FORUM. Sometimes someone else has a solution another group may not have thought of.
No, there's no Tape Monitor loop on this receiver (TAPE 2), so that's why I wanted to know if there was any way to make the TAPE input/output work, as I did not know that ONLY a "monitor" type switch could be used, exclusively. I was searching for any other way to introduce an EQ into the setup, outside of running it between one source and the receiver (which I don't want to do because I want EVERY source equalized).
I've been on this forum long enough for you to know that I'm not a troll -- do me a favor and keep those asinine comments about me being "dense" (looks like I found yet another candidate for my "ignore" list as you're taking a page from other likeminded cruel members here) and "needing attention" to yourself, because that's simply NOT TRUE.
BTW,
Thanks to the complete douche bag who continues to go into my "reputation" protocols, COMPLETELY ANONYMOUSLY (you KNOW who you are) and makes nasty, cruel comments about me, dropping red chicklet after red chicklet just out of personal spite at this point -- I have a feeling I know who this is, but I find it so humorous that someone tells me to "man up" and then there are suddenly ANONYMOUS comments without a name attached to them in my reputation comment area...no, that's not HYPOCRITICAL, AT ALL.
Continuing to hide behind an anonymous comment system is real productive; my hat's off to you, pal. For the record, I was seriously -- without malice or negative intention -- attempting to discover if there was another way to run this EQ through my setup as-is. You want to think otherwise? Be my guest.
Walter:
Did my explanation of what I want to do with the EQ make more sense? You had asked if I wanted to use the CD recorder in the loop, etc...I had explained how I wanted to run it; do you have any more feedback?
Thanks.
Well, here's the rub with this statement: You got answers, over an over. But would you accept them as true? NO!! Just like a little child who thinks that if he rephrases the question, or asks enough different adults, he'll get an answer that he wants to hear. That ain't gonna happen here.
Again, here you show that you didn't even grasp my answer. WTF does "TAPE 2" have to do with anything? All it shows is that you can't even grasp a basic concept when it's laid out in baby steps. ...and you try to come off as all knowing?
From what you seem to be doing with us here, perhaps you should change your moniker to Pearlnecklace.
Yeah, you've been here a long time but have learned, and contributed, nothing aside from stupid posts. Remember, there were two other choices along with troll and, as of this time, the jury is still out on which one of the three is more appropriate.
Oh, as for those red chicklets, none of them are mine ...yet. You see, you can't get any more than you currently have. To bang you now would have no effect and be a waste of my red chicklets. That would be like emptying several clips into someone who is already dead. Now, if you somehow manage to make it to the green and continue playing your games, I might change my mind but, I give you my word that I'll sign it, and I'll send you an email so you know it was me. Fair enough?
Another thing about them... one person cannot bang you over and over again. they have to wait for some period of time before they can bang the same person again. If you keep on getting them, you can rest assured they more than myself find you annoying.
"Knowledge is knowing that a tomato is a fruit; wisdom is knowing not to put it in a fruit salad" - Anonymous
Some of my systems: http://cgi.audioasylum.com/systems/1606.html
anamorphic96 (04-13-2011)
Pearl, you have had the correct advice.
The older vintage gear had a tape monitor loop so that you could use three head recorders, that allowed off tape monitoring. So the source was always at the tape out, if the tape monitor loop switch was to source then you heard the source from the speakers. If you depressed the switch and the tape deck was set to output the play back head during record, then you listed directly to your tape recording from the tape as it was being made. That way you heard problems right away, and could for instance correct tape saturation before it ruined a whole recording.
That same loop could run and equalizer and the equalizer could also run the tape recorder. A DAT machine like your TASCAM does not need a monitor loop, because you can't off tape monitor with a spinning drum recorder like a DAT machine.
If you want that facility then you need to get a nice piece of vintage gear.
You could buy a really nice vintage pre amp and amp for probably around the price of your Onkyo. The right vintage piece would also be the better unit.
Your other alternative is a an external amp, with the Equalizer ahead of the amp. There are good vintage options out there, or new units.
If you can rise to it a Quad 34 or 44 preamp with either a 303 or 405 2 power amp would do you proud. You now have to be a bit patient to find one, but you would not go wrong.
Marantz DV 9600 Oppo BD-83 Marantz AV 8003 Quad current dumping amps X 7 Direct TV HD 20 HD DVR Carter audio workstation RME Fireface 800 Fujitsu 50XHA40 Front left and right Carter dual transmission line studio monitors MK II. Center Carter coaxial transmission line center speaker Rear Carter NFM-1s Center backs Carter dual transmission line studio monitors MK I. My system: - http://mdcarter.smugmug.com/gallery/...27077317_Pufg7
