Results 1 to 2 of 2
Thread: Yamaha Rx-v650 Vcr Feed
  1. #1
    renozabo is offline Audiophyte renozabo is a forum member in good standing
    Join Date
    Jan 2005
    Location
    Reno, NV
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default Yamaha Rx-v650 Vcr Feed
    I have installed my new Yamaha RX-V650 receiver according to the manual. I have the receiver feeding the VCR input and the VCR output back to the receiver as shown. I get no signal out from the receiver to the VCR. I have tried everything I know in the system setup but no luck. All connections are of the same type so it is not a conversion problem. Everthing works correctly when I play a recorded tape on the VCR. Any help will be much appreciated.
  2. #2
    Nomo's Avatar
    Nomo is online now Audioholic Samurai Nomo should be listened to
    Join Date
    Oct 2004
    Location
    Wisconsin, Oshkosh, Wearin' the Fox Hat :)
    Posts
    2,806
    Thanks Given
    715
    Thanks Received
    791
    Default
    You may need to assign the input. Take a look at page 57 of your manual. I would have thought it came out of the box set correctly but maybe not.
    Start there.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
