Page 2 of 22 FirstFirst 123412 ... LastLast
Results 11 to 20 of 220
Thread: Marantz AV7005 Networking A/V Processor Review
  1. #11
    ratso's Avatar
    ratso is offline Full Audioholic ratso should be listened to
    Join Date
    Sep 2008
    Posts
    425
    Thanks Given
    36
    Thanks Received
    93
    Default
    nope, good review!
    samsung PN50B550, Oppo BD-80, Wii, PS3 Slim, Xbox 360, mac mini HTPC, Denon AVR-4311CI, and Axiom QS8 surrounds, dual Rythmik F15 subs, Salk HT2-TL's, selah sardonyx center.
  2. #12
    PENG is offline Audioholic Spartan PENG should be listened to
    Join Date
    Oct 2004
    Location
    Ontario
    Posts
    5,315
    Thanks Given
    1,215
    Thanks Received
    1,440
    Default
    I was considering the SR7005 but I am disappointed with it's measured (HTM) cross talk and SN figures. The power amp section seems weak too but that doesn't bother me. I hope the AV7005 can do better. Otherwise given that I want to stick with Audyssey, I would have to wait for the 4811.
  3. #13
    AcuDefTechGuy's Avatar
    AcuDefTechGuy is online now Audioholic Overlord AcuDefTechGuy should be listened to
    Join Date
    Jul 2007
    Location
    Krypton
    Posts
    13,566
    Thanks Given
    3,376
    Thanks Received
    3,026
    Default
    Quote Originally Posted by PENG View Post
    Where was the review? HTM?
    What were the values?
    Personally, being a Spec-whore that I am, I wouldn't touch anything that doesn't have at least a -90dB crosstalk and 100dB SNR.
    And then when I see crosstalk values in the -50s dB or -60s dB @ 1kHz, I start laughing out loud.
    REVEL SALON2 . B&W 802D2 . KEF 201/2 (6) . LINKWITZ ORION3 . TAD 2201 . DYNAUDIO X32 . FOCAL 826V . ATC SCM7 . PHILHARMONIC 3 . FUNK 18.0 (2) . RBH SX-1010N (2) . VELODYNE SC600 (4) . PIONEER MM301 (8) . DENON AVP-A1HD/AVR-5308/AVR-3312/DVD-3800BD . ATI 3005/3002/2004/6012 . BENQ W6000 . ADCOM GFS-600 . APPLE TV . KIMBER KABLE 8PR
    My System Photo . My System Video
  4. #14
    jostenmeat is offline Audioholic Spartan jostenmeat should be listened to
    Join Date
    Feb 2007
    Posts
    6,781
    Thanks Given
    3,090
    Thanks Received
    2,902
    Default
    Ok, I have to ask what's wrong with the 4311?
  5. #15
    Join Date
    Oct 2004
    Location
    Ontario
    Posts
    5,315
    Thanks Given
    1,215
    Thanks Received
    1,440
    Default
    Quote Originally Posted by jostenmeat View Post
    Nothing gold plated, no AL24 advanced (4308/10 have that in all 7 channels), no wifi etc, nothing really wrong other than going from the 4308 it would make me feel like a very minor upgrade in terms of HDMI inputs and a little downgrade in the other departments.
  6. The Following User Says Thank You to PENG For This Useful Post:
    jostenmeat (12-06-2010)
  7. #16
    Join Date
    Oct 2004
    Location
    Ontario
    Posts
    5,315
    Thanks Given
    1,215
    Thanks Received
    1,440
    Default
    Quote Originally Posted by AcuDefTechGuy View Post
    From the Jan 2011 issue I received in the mail on Friday:
    Cross talk L to R, Cross talk R to L, SN
    Yamaha RX-A2000 -87.13 -83.44 -107.68
    Pioneer VSX-1120 -89.92 -87.33 -102.7
    Marantz SR7005 -77.2 -76.63 -98
    All 3 reviews were done by Mr. Mark Fleischmann so I assume the test procedures were the same. He gave all 3 top pick with 5 stars for performance. I think the Marantz has good enough numbers and the others are just better. The Yamaha would have been my choice if it had the Audyssey XT32.
    Mid range Denon and Yamaha AVRs do seem to yield better HTM measured specs except for power outputs. I no longer value their measured ACD output numbers unless they can take their measurements with the protective circuits disabled. Otherwise those with more aggressive (probably means more advanced in some cases) protective systems will always yield much lower ACD (typically 7 channel driven) numbers.
    I am hoping to see some measurements for the AV7005 soon. Since it does not include the power amp section so for a fair comparison with the likes of the RX-A2000 and AVR-4311 I would like to say something >-110 dBrA
  8. #17
    Join Date
    Jul 2007
    Location
    Krypton
    Posts
    13,566
    Thanks Given
    3,376
    Thanks Received
    3,026
    Default
    Jan 2011 HTM issue:
    Marantz SR7005: -76.63dB Crosstalk, -98dB SNR @ 1kHz, 1watt
    Yeah, I wouldn't buy it either.
    What about this (also HTM):
    Arcam AVR500 $3,500: -76.83dB Crosstalk, -94.52dB SNR @ 1kHz, 1watt
    And people say Arcam is all that???
    And what about this:
    AudioControl Concert AVR-1 $5,500: -75.00dB Crosstalk, -99.24dB SNR
    http://www.hometheater.com/receivers...er/index3.html
    How pathetic of a Crosstalk is that for a $5,500 AVR?
  9. #18
    eddie is offline Junior Audioholic eddie is a forum member in good standing
    Join Date
    Mar 2005
    Posts
    86
    Thanks Given
    3
    Thanks Received
    5
    Default Someone Had to Ask!!!
    How does this compare to the UMC-1 in sound quality? I know the Marantz has it beat feature-wise, but in just sound quality I think it would be close. Anyone care to offer a reply if you've heard both units?
  10. The Following User Says Thank You to eddie For This Useful Post:
    bhodge (12-06-2010)
  11. #19
    adk highlander's Avatar
    adk highlander is offline Moderator adk highlander should be listened to
    Join Date
    Nov 2006
    Location
    Whiteface
    Posts
    2,922
    Thanks Given
    2,326
    Thanks Received
    1,401
    Default
    Stopped into my dealer and he gave me a number I could not refuse. I now have one on order.
    Now I need to sell the 885.
    Theater Office
    Projector: Mitsubishi HC5500 Screen: 84" Severtson tab tension Display: Westinghouse LVM-42W2
    PrePro: Marantz AV7005 Amps: ATI AT2002/2005 Universal Player: BDP-83 Media Player: C-200 Server: RAID5 8TB
    Mains: Wharfedale EVO2-50 Center: Opus Tri Surrounds: Sonance 623T & SRS1 Subs: Snell ICS-24mk3/LFM-1
    Control: URC MSC-400/MX-980 Lighting: Lutron Maestro
    A diplomat is someone who tells you to go to hell in such a way that you look forward to the trip.
  12. #20
    Join Date
    Oct 2004
    Location
    Ontario
    Posts
    5,315
    Thanks Given
    1,215
    Thanks Received
    1,440
    Default
    I also thought the AVR300 sounded very sweet a few years ago when I was shopping for speakers. Over time I realized that it was partially due to the speakers (it was hooked up to the Veritas that I ended up with) and the fact that I had previously read rave reviews on Arcam products so there were elements of preconception and Placebo effects at work.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
