Gotta Have It!
admin should be listened to
Bryston LTD announced that their much anticipated SP3 surround processor (audio only version) will be on operational display at CEDIA 2010. The SP3 surround processor has been engineered to deliver ultimate performance surround sound playback. Slated to be available in two versions, the SP3 at CEDIA 2010 will feature audio processing (with all of the latest DTS and Dolby high definition formats); however a modular video processing board will become available next year for those consumers who wish to add video processing capabilities. The SP3 will feature ultimate performance Class A discrete analog circuits and isolated dual power supplies, one each for the digital and analog sections of the device.
Discuss "Bryston SP3 Surround Processor Preview" here. Read the article.
Gotta Have It!
Integra DTC-9.8/Emotiva MPS-1/Sony R60XBR2 SXRD/PS3/XBOX360/Toshiba HD-A30/D*TV/Sony DVP-CX777ES x 3/Escient DVDM-100/Sony BDP-S1000ES/BDI Racks/RGPC & Furman Line Conditioners/DefTech SuperCube Ref/Paradigm Reference Loudspeakers/AKG K701 Cans/Transparent Digital & Analog IC's/Canare 4S11 Speaker Cables/Emotiva X-Series Power & HDMI Cables/Harmony One Remote/Auralex & ViaBlue Acoustic Treatment/DVDO Edge/VPI Classic Turntable/BAT VK-P5 Phono Stage
I'll wait to see how it actually measures out on the bench to pass judgement.
It may be a "must-have" for folks who already own Bryston amps and want a matching set for aesthetics sake. But unless it kills everything else out there on the bench, it's just another "me-too-been-there-done-it" pre-pro.![]()
REVEL SALON2 . B&W 802D2 . KEF 201/2 (6) . LINKWITZ ORION3 . TAD 2201 . DYNAUDIO X32 . FOCAL 826V . ATC SCM7 . PHILHARMONIC 3 . FUNK 18.0 (2) . RBH SX-1010N (2) . VELODYNE SC600 (4) . PIONEER MM301 (8) . DENON AVP-A1HD/AVR-5308/AVR-3312/DVD-3800BD . ATI 3005/3002/2004/6012 . BENQ W6000 . ADCOM GFS-600 . APPLE TV . KIMBER KABLE 8PR
My System Photo . My System Video
I like the idea that Bryston decided to modularize the video component porcessing as it appears that this technonolgy is still evolving. Not much more can be doen to lossless audio so that part is covered. Based on the SP2 specs below and the 5year warranty, I would say that this gives the Anthem a good run for the money.
A/D Conversion: 24-Bit, 48kHz Delta-Sigma
D/A Conversion: 24-Bit, up to 96kHz Delta-Sigma
DSP Engine: TI Aureus
Power Supply: Dual, Linear, Toroidal
Frequency Response: 20Hz to 20kHz +/- 0.25 dB
THD+Noise: Less than 0.006% in DSP modes; Less than 0.0025% in
Bypass mode 20Hz to 20kHz at maximum output level.
Signal-to-Noise Ratio: 105dB in DSP Modes; 110dB in 2ch Bypass Mode ; 22kHz
bandwidth, Ref. 1kHz at maximum output level
Input Level: 2 Vrms in DSP modes; 4 Vrms in Bypass Mode
Input Impedance: 50kOhms
Output Level: 8 Vrms (16 Vrms Balanced) in DSP Modes; 10 Vrms (20
Vrms Balanced) in Bypass Mode.
Output Impedance: 110 Ohms
Bass Management: 2nd Order HP filter(x5), 4th Order LP filter 40 – 200 Hz Crossover
Freq.
PHYSICAL SPECIFICATIONS
Power Requirements 100VAC, 115VAC, and 230VAC models. 200 VA. IEC detachable
power cord (included)
Dimensions: 17” W x 13.5” D x 3.8” H; rackmount 19” W x 13.5” D x 3.5” H
Weight: approx 22 lbs (10 kg)
Chassis Temp: 50 deg Celsius max.
Specifications subject to change without notice.
