Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: 2 Channel amp for bookshelf speakers
  1. #11
    wire's Avatar
    wire is offline Senior Audioholic wire has very reliable input
    Join Date
    Jul 2006
    Posts
    626
    Thanks Given
    22
    Thanks Received
    18
    Default
    Quote Originally Posted by Tungsten06GT View Post
    Well, I'm focusing my efforts on pimping out the bedroom now. I'm going to be putting a 32" lcd in, and was thinking of doing a simple 2 channel bookshelf setup (and possibly a sub too) with some kind of pre-amp. I was quite intrigued by EMP's tube amplifier, but what would be some other routes to go? Thanks
    I run a Onix sp3 in my room , very nice . http://www.audiogon.com/cgi-bin/cls....mkii-unopened-
    Ive seen used go much cheaper than the link
    Main Room-Carver CT-7/Bryston4b/Polk2b/Denon DCM370
    Bedroom-Onix SP3/NuanceStar1/CarverC-9/Denon DCM380
    Movieroom -Sunfiretheater grand II /Carver AV 505/Toshiba5915/Klipsch/KlipschRW-8 Sub
    Computer - CT-17/ TFM-35/ Carver bookshelfs /Polkpsw10sub
  2. #12
    Jeff R. is offline Senior Audioholic Jeff R. has very reliable input
    Join Date
    Dec 2008
    Location
    Charlotte, NC
    Posts
    636
    Thanks Given
    139
    Thanks Received
    75
    Default
    I second the HK option. I bought my HK 3490 about 1 year ago and love it. I got it from www.jr.com, it think I paid about $350-375. It has serious power for the price. All the digital inputs you need and sub out. The only negative is that is does not have any bass management system, so the speaker will play full range, unless you run the speaker wires through the sub and let it cross over for you. You may want to check out www.accessories4ess.com They usually have some great deals on refub Marantz receivers that may suit your need.
    Home Theatre System (5.2):
    TV: 60" Hitachi DLP
    Reciever:Onkyo 805
    DVD: PS3
    Fronts: PSB Image 6T
    Center: PSB Image 6C
    Surrounds: Swans Diva 4.2
    Subs: 2 x ED A2-300
    Family Room System (3.2)
    TV: 55" Sony LCD
    Receiver: Onkyo 708
    Amp: Emotiva XPA-3
    CD: Denon DCM-290
    Fronts: MB Quart QLS-1030
    Center: MB Quart QLS-330
    Subs: 2 x 10" Eclipse SW8102 in sealed boxes -Amp - Adcom GFA-555
  3. #13
    Chicagorep is offline Junior Audioholic Chicagorep is gaining some recognition
    Join Date
    Jan 2010
    Location
    Round Lake
    Posts
    98
    Thanks Given
    0
    Thanks Received
    12
  4. #14
    Tungsten06GT is offline Audioholic Tungsten06GT is gaining some recognition
    Join Date
    Nov 2009
    Posts
    226
    Thanks Given
    21
    Thanks Received
    14
    Default
    Ok let me back up one second. Basic question, if I'm not looking for any video processing since I'm just plugging coax into the back of my tv, then wouldn't I just want an integrated amplifier and not a full receiver?
    Mains: EMP E5ti, Center: EMP E5ci, Surrounds: EMP E5bi, Subwoofer: eD DIY A7s-650, Receiver: Pioneer Elite VSX-21, Display: Samsung LN46A650, Gaming/Blu-ray: PS3
  5. #15
    Join Date
    Jan 2010
    Location
    Round Lake
    Posts
    98
    Thanks Given
    0
    Thanks Received
    12
    Default
    Only if your audio outputs on your TV can control the volume output at the RCA's, if not you need a way to control the volume. That's why I have the Z-pre in my system. Well that and I have my Ipod plug into it, so I use it for source selection too
  6. #16
    Join Date
    Nov 2009
    Posts
    226
    Thanks Given
    21
    Thanks Received
    14
    Default
    Here is the back of my tv, Samsung LN32B360. Nothing special I know, but I still wanted to get decent sound somehow. So, there's an RCA audio out, or Optical. I only have the coax cable plugged in.. Are there any receivers where I'd be able to go straight coax in?
    I'm really confused about what my options are.. sorry! Please help! haha
    Attached Images Attached Images
  7. #17
    j_garcia's Avatar
    j_garcia is offline Seriously, I have no life. j_garcia should be listened to
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,290
    Thanks Given
    1,664
    Thanks Received
    3,807
    Default
    Quote Originally Posted by Chicagorep View Post
    No, an integrated amplifier has a preamp section so you don't need anything in between. A stereo receiver might have video switching as well, but integrated amps typically do not.
    I believe that is the same TV I have in my second system. You simply connect the R&L stereo outs to any stereo input on the integrated amp and it will work. I use my Marantz PM7200 integrated in my second system: My NEW system
    HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
    System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
    Are you sure which side of the glass you are on?
  8. #18
    Join Date
    Jan 2010
    Location
    Round Lake
    Posts
    98
    Thanks Given
    0
    Thanks Received
    12
    Default
    I stand corrected, I glazed over the word integrated and saw only amplifier. An integrated amp will work.
  9. #19
    Join Date
    Nov 2009
    Posts
    226
    Thanks Given
    21
    Thanks Received
    14
    Default
    Can anyone comment on the Pioneer Elite stereo amplifiers, either the A-35R or the M-10X? I've got the Elite 21txh already and love it, so it could be kind of cool to stay with the same brand..
  10. #20
    Join Date
    Nov 2009
    Posts
    226
    Thanks Given
    21
    Thanks Received
    14
    Default
    It looks like those Pioneers may be older perhaps? Can't find them anywhere.
    But, what about entry level Yamaha or Onkyo, like the RX-397 or TX-8255? They don't have a sub out so would I just run the speaker wires in parallel to speaker in on the sub?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
