Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Receiver For Mission Speakers
  1. #11
    ZeroPlex is offline Enthusiast ZeroPlex is a forum member in good standing
    Join Date
    Feb 2010
    Posts
    24
    Thanks Given
    13
    Thanks Received
    0
    Default
    Thanks guys.
    Seth,
    The Sony Amp I had before was an STR-DB930, and there were so many settings in that, including a whole host of DSP Modes that perhaps some things were set so as to augment bass, possibly from the speakers themselves.
    Sholling,
    I did consider one of the new Onkyo 807's, which is apparently a monster. 180 watts per channel here in Europe I think it is, but the reviews say that it will completely blow you off the sofa and you'd even need to take a break half way through a movie, so it's a bit beefy in the bass department.
    Maybe it would be my ideal receiver, but there are issues with Onkyo and reliability, plus build quality, which puts me off. What is your opinion on this?
  2. #12
    Join Date
    Feb 2010
    Posts
    24
    Thanks Given
    13
    Thanks Received
    0
    Default
    Just one more thing to add.
    I'm using a Y Link subwoofer cable which I had lying around instead of buying a single RCA to RCA.
    The Y Link I have is a PPX to 2 RCA. It's this cable here:
    http://www.hificablesdirect.com/256/...er-Cable-.html
    It's not any harm to use that connection between the amp and the sub is it? It won't affect performance in any way?
    I have the PPX on the amp side and both RCA's fed into the left and right inputs on the sub.
    Both inputs on the sub are black by the way, and not red and white, or red and black like you see on some others.
  3. #13
    Seth=L's Avatar
    Seth=L is offline Audioholic Overlord Seth=L should be listened to
    Join Date
    Sep 2006
    Posts
    12,034
    Thanks Given
    1,204
    Thanks Received
    1,652
    Default
    That's more than likely true. The solution could be an eq.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
