Im not sure either has HDMI. As for every thing else both are nice units, whats your budget?
Yamahaha is a forum member in good standing
Im planning on buying one of these and hooking it up with bluerayplayer with the 7.1 analog inputs(sound). And pic via hdmi.
Do I loose anything soundwise by doing this instead of taking the sound via hdmi?
How does these 2 amps do compared too todays amps?
Anything special I should have in mind when testing them?
What U think would be a fair price? Always hard with old amps.
Any input regarding these 2 amps is welcome.
Thanks.
bandphan is off the scale
I know neither has hdmi, thats why Im planning too hook it up via the 7.1 analog inputs for sound and take the pic via hdmi direct too the projector.
I have another question.
How does the amplifierstage in these too differ from the one in avc-a1hd?
I think its called 5303ci in the US, not sure.
I got an offer for about 1000$Us for the avc-a1sr. So around 1000$US is my budget.
Both are power houses. I wouldnt think that the amp stages are different at all.
One thing to remember is that all processing is by-passed when the multi-channel inputs are used. Bass management would need to be done in the BD/DVD player and there would be no matrixing of a 5.1 soundtrack when using Dolby True HD/DTS-MA into the rear surrounds if you have them. Only a 7.1 discrete soundtrack would offer sound to the rears.
These are definitely excellent units, I own the 5800, as long as you’re running a 5.1 setup or could live with the standard DD/DTS soundtracks.
What speakers are you running and how large is your room? Where do you live?
Mitsubishi LaserVue L75-A91, Denon AVR-4810CI, Oppo BDP-83, Escient FireBall MX-111, APC H15
Speakers: L/R - ESS AMT Monitor, Def Tech ProCenter C2, UIW BP In-wall, UIW 64 In-ceiling, Dual SVS PB12-PLUS, Def Tech SuperCube I
Zone 2 (3 Areas through Niles HUB8, Niles MSU-480, Niles TS-110 Table Top Sensor & 3 x Niles IM/VC w/IR sensor)
Paradigm CS60R In-ceiling 2 Pair
Exterior -- Backyard Patio
Paradigm Stylus 250
Are You sure?
Isnt that in the pure direct mode?
I thought it was like this.
In pure direct mode.
Signal from BRay -- preamp denon--ampsection denon--- speakers
In not pure direct mode
signal from BRay-- A/D converters--- processors/decoding-- D/Aconverters--preamp denon--ampsect denon--speakers
This is when using 7.1 analog input and letting the bluerayplayer do the decoding.
Speakers system is Audiopro Blue diamond.
No, Pure direct/Direct, on most Denons, still use the bass management but turns off all other processing and only puts out a stereo(L/R) signal. PD/D is used when a digital signal is provided.
But you are correct that it works straight through unmolested.
Paradigm Stylus 250
