Great review!!!
admin should be listened to
With a full compliment of all the latest playback formats including Audyssey DSX and Dolby PLIIz plus top of the line deinterlacing and scaling on board, the Denon AVR-4310CI has everything you'll need to build a sophisticated home theater system. Add to that multiroom support, networkability, and power reserves for all but the most demanding speakers in the largest rooms and you're basically buying a receiver that you'll be hard pressed to replace for a very long time.
Discuss "Denon AVR-4310CI Receiver Review" here. Read the article.
Great review!!!
Mitsubishi LaserVue L75-A91, Denon AVR-4810CI, Oppo BDP-83, Escient FireBall MX-111, APC H15
Speakers: L/R - ESS AMT Monitor, Def Tech ProCenter C2, UIW BP In-wall, UIW 64 In-ceiling, Dual SVS PB12-PLUS, Def Tech SuperCube I
Zone 2 (3 Areas through Niles HUB8, Niles MSU-480, Niles TS-110 Table Top Sensor & 3 x Niles IM/VC w/IR sensor)
Paradigm CS60R In-ceiling 2 Pair
Exterior -- Backyard Patio
Paradigm Stylus 250
rnatalli should be listened to
I believe Denon's allow you to trim the LFE aggressiveness of the Dynamic EQ under the parameter menu.
LFE trim has nothing to do with Dynamic EQ. I am also in agreement with Tom's findings. On most recordings Dynamic EQ tends to over boost bass. I find it useful when listening to 80s style rock music however which tends to be void of bass.I believe Denon's allow you to trim the LFE aggressiveness of the Dynamic EQ under the parameter menu.
Tom is wonderful...he did a nice verbal review on the avrant podcast too...
TV:Samsung PN50B530S2F plasma tv
Rcvr:Pioneer VSX-21THX
DVD:Sony BDP-S350
Speakers:Front/Paradigm Monitor 11 v.5, Surround/Paradigm Atoms V.4, Center/Paradigm CC290 v.5, Sub/Paradigm PDR-12
Remote:Logitech Harmony One
http://s83.photobucket.com/albums/j3...view=slideshow
westcott is considered a mentor
Thanks for the review. I wish I had some coin to upgrade from my 3805.
I went on eBay just to see what they are fetching and my findings suggest I should just keep it and use it elsewhere.
Hope everyone has a great new year!!!
His and Her Room!
Klipsch RF7's,RC7,RS7's,RSW15,Denon 3805, Samsung BD-P1200, Toshiba HD-XA2, VIP622 HD DVR, 100" BW Carada Critereon, Panasonic AE700u, Wega 27",300 Disk CD Changer,Laurier-Carino AV Credenza, Logitech Harmony 1000 with RF extender, Impact Acoustics 5x1 HDMI switch,Tripp Lite HT10DBS, Blue Jean Cables
March 2007 Issue Home Theater Magazine and Audio Video Interiors
I have to say I have been very happy with my 4310 (had for several weeks now). I upgraded from a 3805 and added 2 Def Tech ProMonitor 800's for the height channels. Now I also added 2 additional sound isolation panels at the same time - but the system sounds great!![]()
I reject your reality and substitute my own - Adam Savage
AVRat (02-25-2010),jostenmeat (02-24-2010)
shinam is a forum member in good standing
Has anyone faced the same issue as me?
Issue: It stopped connecting to network after four months of use. Denon repair center (Mahwah, NJ factory location) had to repace the Ethernet card, and after two weeks I see same issue again.
Initially, I had DHCP enabled on Netgear router WGT624. I was told to uncheck UPnP feature on router by my dealer and then I also gave a static IP (some middle IP address in the subnet range) to AVR. But issue reappeared.
Thanks,
Shinam
I've had a difficult time connecting to the network. I continued trying and it worked fine. I won't try to connect it while my computer is on the net. I get an error two computers are using the same IP address response when I did. I couldn't get them to run together even after troubleshooting.
