Results 1 to 3 of 3
Thread: Yamaha RX-V765 hiss
  1. #1
    salietata is offline Audiophyte salietata is a forum member in good standing
    Join Date
    Dec 2009
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default Yamaha RX-V765 hiss
    I have a yamaha rx-v765 and the left speaker channel constantly hisses. I double checked my speaker cables and switched speakers so I know those aren't the issue.
    I unplugged everything so right now I just have the receiver and 2 front speakers. When I turn it on, like I said, the left channel constantly hisses. The other thing I noticed is that when I turn the receiver off, it makes a popping noise in that channel. I took the cover off to see if I could see any loose wires, but everything looks legit to me, but I'm not a big audio guy so there could be something I'm missing.
    Does anyone have any idea what could be wrong?
  2. #2
    nzimm is offline Audiophyte nzimm is a forum member in good standing
    Join Date
    Apr 2010
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default
    I have the exact same problem with my RX-V765. Did you ever figure out a solution?
  3. #3
    TLS Guy's Avatar
    TLS Guy is offline Audioholic Warlord TLS Guy should be listened to
    Join Date
    Oct 2007
    Location
    Benedict MN
    Posts
    9,876
    Thanks Given
    865
    Thanks Received
    4,017
    Default
    Quote Originally Posted by nzimm View Post
    It will need service, there is either a leaky cap, a bad solid state device junction or a noisy resistor. You won't solve this yourself unless you have the skill and the test equipment.
    Marantz DV 9600 Oppo BD-83 Marantz AV 8003 Quad current dumping amps X 7 Direct TV HD 20 HD DVR Carter audio workstation RME Fireface 800 Fujitsu 50XHA40 Front left and right Carter dual transmission line studio monitors MK II. Center Carter coaxial transmission line center speaker Rear Carter NFM-1s Center backs Carter dual transmission line studio monitors MK I. My system: - http://mdcarter.smugmug.com/gallery/...27077317_Pufg7
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
