Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Sony STR-DG810 AV Receiver First Look
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Sony STR-DG810 AV Receiver First Look
    If you are like me, you may have acquired more high definition sources than your current AV receiver can accommodate. My case isn't made any better by the fact that my projector is just old enough to not offer an HDMI input. Well, for under $300, Sony now offers the STR-DG810 that will allow you to connect up to three high definition sources by HDMI or component video inputs.
    Discuss "Sony STR-DG810 AV Receiver" here. Read the article.
  2. #2
    obscbyclouds's Avatar
    obscbyclouds is offline Senior Audioholic obscbyclouds has a small fan club
    Join Date
    Mar 2005
    Location
    Acton, MA
    Posts
    586
    Thanks Given
    49
    Thanks Received
    80
    Default
    Beware if you are using this reciever for HDMI switching! I had big time picture dropouts when I used the STR-DG800. I do not know if these problems have been addressed. Switching from Cable to my Oppo DVD player was a nightmare, as i ended up having to turn everything off, and then on again in the proper order. It was kind of like where they're trying to get Apollo 13 re-enty only using 12 Amps!
    This species has amused itself to death.
  3. #3
    Clint DeBoer's Avatar
    Clint DeBoer is offline Administrator Clint DeBoer should be listened to
    Join Date
    Jul 2002
    Location
    Lakeland, Florida, United States
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default
    To be fair, that might be more or less the fault of thge cable box... With HDMI there are so many variables it's tough even to troubleshoot effectively using the regular methods.
    Clint DeBoer
    Editor in Chief
    Audioholics
  4. The Following User Says Thank You to Clint DeBoer For This Useful Post:
    bandphan (01-28-2008)
  5. #4
    gus6464 is offline Audioholic Samurai gus6464 is looking for a job at AH
    Join Date
    May 2007
    Posts
    2,302
    Thanks Given
    144
    Thanks Received
    388
    Default
    There are a lot of receivers out there that have HDMI handshake issues including some higher end ones.
    Panasonic TH-50PX75U Plasma
    Yamaha RX-V661
    Mirage Omni 550
    Mirage Omni C150
    Mirage Omni 150
    Sony SA-W2500 (until svs or hsu sub)
    Sony Playstation 3
    Toshiba HD-A3
    Nintendo Wii
    Office system (2ch only)
    Dali Ikon 2
    Rega Planar 2 w/ AT440MLa cart
    Rolls Bellari tube phono preamp
    Sony STR-DE675 AVR
    Samsung DVD-HD841 (sacd player)
  6. #5
    Cygnus is online now Senior Audioholic Cygnus should be listened to
    Join Date
    Mar 2005
    Posts
    643
    Thanks Given
    81
    Thanks Received
    24
    Default
    Ohh....Sony? Really? I havent had very much luck with any of their A/V products, and they tend to be looked down upon by the AV communities. I'm surprised this even got a review.
    AVR: Denon AVR-3311CI Bluray: Playstation 3 DVD: LG LDA-530
    Streaming: Apple TV 2 Digital Cable: Telus TV Digital Cable Box Panel: Samsung 46" 1080p 120Hz Record player: Technics SL-1200MK2 (with Ortofon 2M Red cart) Speakers: Fronts: Paradigm Monitor 7 v.6, Center: Paradigm CC-190 v.6, Side, Surrounds: Paradigm Mini Monitor v.6, Back Surrounds: Yamaha NS-5290
  7. #6
    widget is offline Audiophyte widget is a forum member in good standing
    Join Date
    Apr 2008
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default SONY "Protect" Problem
    Okay...any help here greatly appreciated...
    I have the Sony STR-810. It powers two single-channel stereo ceiling speakers and two independent, dual channel speakers in ceiling as well.
    As soon as I get to a moderately (and I mean moderate....about 42 on the digital volume level) loud level the unit goes into "protect" mode and shuts down.
    What gives? I double checked connections and all seems well to me. But I am admittedly a novice of sorts...
    Thanks in advance,
    Widget
  8. #7
    pugcharlie is offline Audiophyte pugcharlie is a forum member in good standing
    Join Date
    Mar 2009
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Angry SONY STR-DG810 Protect Mode All The TIME!
    Quote Originally Posted by widget View Post
    Thanks in advance,
    Widget
    I have the same piece of crap. I bought this receiver to replace my non- HDMI Sony Home Theater receiver because except for slightly less power, it has 3 HDMI in and one out. For a year and a half, it was fine. I moved October 15th...used all new 16 gauge speaker wire, everything is wired fine and now with any surge in sound-even at a 42 sound level, it goes into PROTECT mode and shuts down. It does this with DirecTV too. I am not happy that i didn't replace it with 7.1 but I didn't think I'd be moving and all that conduit stuck to wallboard, the thought of ripping it ll down and getting another speaker was too much. Now this receiver is worth nothing. No more Sony audio products...
  9. #8
    Adam's Avatar
    Adam is online now Audioholic Jedi Adam should be listened to
    Join Date
    Jul 2006
    Location
    Tucson, Arizona
    Posts
    26,521
    Thanks Given
    7,581
    Thanks Received
    9,126
    Default
    Quote Originally Posted by pugcharlie View Post
    Welcome to the forum!
    Do you have the receiver hooked up to the same speakers as you did before you moved? If so, it is probably something in the connections. Make sure that you don't have any copper strands bridging across from one binding post to another (either on a speaker or on your receiver). These things do happen, and they'll cause a partial short that could put your receiver into protect mode.
    Mains and Surrounds: NHT 1.5s, Center: NHT AudioCenter-1, Subs: SVS PC13-Ultra, SB13-Ultra, Receiver: Pioneer Elite VSX-23, Amps: Emotiva RPA-1, POS-1, Display: Panasonic TC-P50G10
  10. #9
    lsiberian's Avatar
    lsiberian is offline Audioholic Overlord lsiberian should be listened to
    Join Date
    Nov 2008
    Location
    On A Bridge in Fort Worth
    Posts
    10,475
    Thanks Given
    4,235
    Thanks Received
    2,526
    Default
    This topic is over a year old.
    Protect mode is a common Sony Product and is probably cause by driving the amp to hard.
    42 seems like a very high level on a sony amp. I think it's time for you to upgrade.
    Fronts:Madisound RB Kits Rears and Sides: Kef 2001.2, Subwoofer: TC Tiger-1000
    Receiver:Onkyo NR-708 Amp: Behringer EP4000 Players: Panasonic BDP-60, Onkyo DX-C390 Projector: Epson 8350 Screen: FAVI PD-HD-92
    Funny Quote(s):
    That's like trying to get decent sound in a public lavatory.-TLS Guy
    Heck, if you've got the cash, go the NSA supercomputer route and use Fluorinert- Adam
    A shovel of dirt can stop a flood. -Westom
  11. #10
    tom67 is offline Full Audioholic tom67 is looking for a job at AH
    Join Date
    Jul 2007
    Location
    Palm Beach Fl
    Posts
    373
    Thanks Given
    1
    Thanks Received
    46
    Default Newer Sony Receivers
    nope....Sonys have better connectivity than Yamaha etal at this point for less money....there is anti Sony bias here not based on fact
    http://reviews.cnet.com/best-value-a...rColumnArea1.1
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
