Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Yamaha Drops Entry Price for Feature-laden Receivers
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Yamaha Drops Entry Price for Feature-laden Receivers
    According to an article at twice.com, Yamaha is launching four new A/V receivers that drop the price of entry for consumers looking for some of the hottest new technology available on the consumer electronics market.
    Discuss "Yamaha Drops Entry Price for Feature-laden Receivers" here. Read the article.
  2. #2
    GlocksRock's Avatar
    GlocksRock is online now Audioholic Spartan GlocksRock should be listened to
    Join Date
    Oct 2005
    Location
    Charlotte, NC
    Posts
    6,139
    Thanks Given
    287
    Thanks Received
    910
    Default
    Sounds like a great plan to me. This should induce some healthy competition that will benefit all.
    SHARP Aquos LC70LE640U
    Denon AVR-4311ci, Emotiva IPS-1
    APC H15 Power Conditioner
    PS3, Wii, XBOX 360 Elite Slim
    Dell Inspiron 660 HTPC
    Def Tech BP7001SC, CLR3000, BPX, BP10, BP2X
    SVS PB13-Ultra on Great Gramma
    Harmony One
    Bedroom System
    Samsung PN58C590
    Explorer 4250 HD cable box
    Yamaha RX-V1800 Onkyo M-5140 amp
    Xbox 360 Elite, PS3 Slim
    Dell Vostro 400 HTPC
    Def Tech BP7006, CLR2300, BPX
    SVS PC12 Ultra & 20-39PC+ on Subdude HD
    Panamax M8-HT-Pro
    Harmony One
  3. #3
    blruggles is offline Audiophyte blruggles is a forum member in good standing
    Join Date
    Feb 2007
    Posts
    6
    Thanks Given
    0
    Thanks Received
    0
    Default About time and long overdue..
    As a network administrator and someone that works in IT daily these "SCRIPT" features are long overdue on receivers in the audio market....
    With all the various settings in todays HT receivers, it only makes sense to have preprogrammed settings that you can switch back and forth to. They should have at least 10.
    Good to see Yamaha finally focus in on better end user controls and cost reduction.
    Now if they can just do a better job on the Remote Controls, why can't they add a simple SEEK button on the RC to easily scan up and down on the FM tuner similar to an FM radio in a car.
    Yamaha HTR-5760
    SONY DVD-NCP875V
    Fronts - BIC DV62CLR-s
    Center BIC DV62CLR-s
    Rears BIC DV62si
  4. #4
    Bassman2 is offline Audioholic Bassman2 is gaining some recognition
    Join Date
    Mar 2007
    Posts
    115
    Thanks Given
    0
    Thanks Received
    1
    Default
    Well at first I was worried because I JUST bought an RX-V659 but after reading the article I see the new stuff is nothing I either need or really want. Sure it would be nice to have a pre set volume but I just take the time between hitting power and when the relays click on, to hold the volume button down. Besides it all sounds like it could be put on a two dollar chip and that the only reason it wasn't on the receivers to begin with was to get people to spend up. Just my nickel... minus three pennies.
  5. #5
    angstadt530 is offline Audioholic angstadt530 is a forum member in good standing
    Join Date
    Dec 2006
    Posts
    112
    Thanks Given
    0
    Thanks Received
    0
    Default
    With the exception of the lack of pre-outs, this seems like the receiver I've been waiting for...
    I know these receivers will support 6 and 8 ohm speakers, but would I be ok running 4 ohm speakers through one? My current speakers are 6 ohm, but I'm just wondering for future reference.
  6. #6
    j_garcia's Avatar
    j_garcia is offline Seriously, I have no life. j_garcia should be listened to
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,290
    Thanks Given
    1,664
    Thanks Received
    3,807
    Default
    Well, sounds great as long as they aren't cutting corners somewhere else to make those prices profitable...as long as they keep their honest power numbers, the feature set looks great for the prices.
    HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
    System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
    Are you sure which side of the glass you are on?
  7. #7
    jonnythan's Avatar
    jonnythan is online now Audioholic Ninja jonnythan should be listened to
    Join Date
    Jan 2006
    Posts
    3,054
    Thanks Given
    103
    Thanks Received
    415
    Default
    That's hotter than your mom.
  8. #8
    Tsunamii's Avatar
    Tsunamii is offline Full Audioholic Tsunamii is a forum member in good standing
    Join Date
    May 2004
    Location
    Sudbury Ma
    Posts
    357
    Thanks Given
    0
    Thanks Received
    0
    Default
    Great price point. A white box running LMC and a couple of these and a multi zone setup starts looking pretty cheap with some cool features to match it.
  9. #9
    zoran is offline Audioholic zoran is a forum member in good standing
    Join Date
    Apr 2005
    Posts
    202
    Thanks Given
    3
    Thanks Received
    0
    Default
    HDMI ver 1.3?
  10. #10
    jackdean101 is offline Audioholic Intern jackdean101 is a forum member in good standing
    Join Date
    Oct 2006
    Posts
    37
    Thanks Given
    3
    Thanks Received
    0
    Default RX-V661 ($499) vs RX-V861 ($999)
    I have read through the spec page on the Yamaha website and I can't figure out what the big difference is between these two recievers. The only thing I can come up w/ is 15 w per channel, and I don't believe that grants the $500 difference.
    http://www.yamaha.com/yec/products/p...ETYP=ATTRIBUTE
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
